Re: 440-1 head upgrade
[Re: AndyF]
#2400046
11/07/17 05:30 PM
11/07/17 05:30 PM
Posts: 427 Sweden
Mopar Guy
Sweden
Talk to Dwayne at Porter Racing Heads. He has a lot of experience with the Indy stuff. Dwayne is where i also would turn to !!!!!
[Re: AndyF]
#2400113
11/07/17 07:37 PM
11/07/17 07:37 PM
Posts: 10,007 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Talk to Dwayne at Porter Racing Heads. He has a lot of experience with the Indy stuff. The 2.25 valve and matching port work is as good as it gets. I tried a 2.3 valve and got zero gains and a $1,000 bill. Do you have enough motor to warrant the extra head work?
[Re: sgcuda]
#2400382
11/08/17 11:25 AM
11/08/17 11:25 AM
Posts: 20,178 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Not if they turn into sprinklers
[Re: 301v]
#2400467
11/08/17 01:33 PM
11/08/17 01:33 PM
Posts: 14,499 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I don't recall having a 325 and 345 in the shop at the same time, but my perception of the two different port configurations is that the 325 short turn shape and height is different enough from the 345, that I'm not sure a 325 can be made turned into the Indy cnc345....... Not exactly anyway. It seemed to me as though the floor on the 325 was slightly lower, and rounder.
Might be worth a call to Indy and see what they say.
The exhaust ports and chambers are the same between the two.
I have put 2.25's in the 325's before, and that usually gets them to flow very closely to the 345's up til about .700 lift or so, then the 345 starts to pull away.
Depending on the overall combo....... Even 345's can be pretty small for a high effort 572.
I'll also add that if the OP's 325's are as delivered from Indy, if they are like every other set of those I've seen...... Then there is some flow left on the table.
[Re: 301v]
#2400483
11/08/17 02:01 PM
11/08/17 02:01 PM
fast68plymouth
So. Burlington, Vt.
I would def put the 2.25's in when they get freshened. Maybe try some 1.6 or 1.65 intake rockers too.
As an example-
A- ootb cnc 325, Indy valve job and valve B- cnc 325 with PRH valve job and blend, 2.25 Manley valve C- cnc 345 with PRH valve job and blend, 2.25 Manley valve
Lift--------A/B----C .100---71.9/75.9----76.1 .200--142.7/153.7-153.8 .300--210.3/217.1-217.9 .400--268.3/275.1-277.1 .500--313.7/326.9-327.6 .550--325.0/343.2-345.9 .600--332.6/356.8-358.3 .650--340.2/362.3-368.3 .700--349.6/364.2-377.8 .750--355.3/371.5-381.7
