Torsion bars...what do you run? #2398036
11/03/17 05:22 PM
11/03/17 05:22 PM
Northern N.J.
hemi_doug Offline OP
Northern N.J.
Looking to start in on the front end on my 10.0 65 Satellite. Car came with 318 poly. I want to replace the old bars with something that isn't 42 years old. so what is the best bar for a 10.0 race car?
71 440-6 4spd & 69 Hemi 4spd
Re: Torsion bars...what do you run? [Re: hemi_doug] #2398037
11/03/17 05:27 PM
11/03/17 05:27 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Mopar made drag race specific torsion bars. I think they were .840 diameter? They were sold out when I built my car so I used 6 cylinder bars.
2011 Drag Pak Challenger
Re: Torsion bars...what do you run? [Re: hemi_doug] #2398090
11/03/17 07:01 PM
11/03/17 07:01 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I'm running the 340 bars .840 iirc and they work great w/the BB compared to the .810's that were a bit too sloppy............ thumbs
Re: Torsion bars...what do you run? [Re: hemi_doug] #2398093
11/03/17 07:05 PM
11/03/17 07:05 PM
long time lurker, short time p...
P
PorkyPig Offline
PorkyPig  Offline
P
Mine are either .86 or .88, I don't remember which. They came out of a 318 car if that helps.
I know the A body bars are thinner than the B or E bodies had for the same engine.
Re: Torsion bars...what do you run? [Re: hemi_doug] #2398136
11/03/17 08:59 PM
11/03/17 08:59 PM
Northern N.J.
Northern N.J.
Jegs has a Mopar .890 P5249150 set..think that would work?
Scratch that...they were A body. Crap..
Re: Torsion bars...what do you run? [Re: hemi_doug] #2398233
11/04/17 01:20 AM
11/04/17 01:20 AM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
My Demon is a original 340 car and I kept the 340 bars in it,running a 440.
Nautilus Racing-
Re: Torsion bars...what do you run? [Re: hemi_doug] #2398292
11/04/17 08:34 AM
11/04/17 08:34 AM
Mo.
racerx Offline
racerx  Offline
Mo.
8.20's here BB wave
Re: Torsion bars...what do you run? [Re: hemi_doug] #2398301
11/04/17 08:58 AM
11/04/17 08:58 AM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
.810 MP drag bars in my small block A-body, 3100lbs., that sees street time, and has 600 hp on tap, and then add the nitrous. They are not strong enough, and have too much stored energy, especially for a ladder bar car at this power level. Just ordered the .890 bars from Summit.
Summit carries the Mopar Performance B body bars in .920 and .960, I would measure what you have now, and then decide.
racerx can pull the front wheels in a car wash, that thing is loose!
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: Torsion bars...what do you run? [Re: hemi_doug] #2398309
11/04/17 09:22 AM
11/04/17 09:22 AM
Tulsa OK
Bad340fish Online content
Bad340fish  Online Content
Tulsa OK
I run the slant six bars in my A-body. She is a fat fish though at 3600lbs. They are doing fine holding up the R1 Block with W2 heads which I assume approaches big block territory for weight. I have some thinner race bars to try but I haven't felt I needed them.
68 Barracuda Formula S 340
Re: Torsion bars...what do you run? [Re: hemi_doug] #2398313
11/04/17 09:39 AM
11/04/17 09:39 AM
Minn
SportF Offline
SportF  Offline
Minn
Note some of the comments above on small bars.
I ran 6 cylinder bars for a very short time. But, just driving around the pits the thing was bouncy/sloppy to the point I took them out.
Also, I've been running 50 year old bars on my cars for years.
They might be like thermostats. A good working used one is better than a untested new one.
Re: Torsion bars...what do you run? [Re: MoparBilly] #2398421
11/04/17 04:08 PM
11/04/17 04:08 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
Hi Billy, that's a pretty big jump in #/inch.
.810 = 90 #/in
.890 = 130 #/in from the mp chassis book.
.850 (318) bars is not listed in the chassis book. .20" in diameter goes up 10 #/in so I figure mine are 110 #/in
Years ago I wanted new bars in my Barracuda I got the .890 (resto 383) I did not like em! I sold them and got .850 (318) bars, swap meet.
I didn't get the load transfer I needed with the .890 bars. That was with my 451 ci 660 HP.
I have a BB and when I used the .810 drag bars they barely held up the front. sold them also.
Let us know how they work. Yours is a street car while mine is drag only.
Do you feel older?
Don
Re: Torsion bars...what do you run? [Re: cudadon] #2398490
11/04/17 07:13 PM
11/04/17 07:13 PM
IN
ahy Offline
ahy  Offline
IN
There is some variation in QC with the new bars. Firm Feel is good and MP (when they were available) seemed OK. Some of the others not so much.
If your old bars do not show deep scratches or other damage on visual inspection they should be fine to run IMO.
Re: Torsion bars...what do you run? [Re: hemi_doug] #2398723
11/05/17 11:07 AM
11/05/17 11:07 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I've had no issue with the stock 6 cylinder bars, 550 passes so far.
Doug
Re: Torsion bars...what do you run? [Re: hemi_doug] #2398767
11/05/17 12:44 PM
11/05/17 12:44 PM
Big Western Pencilveinya
U
Uncle Barry Offline
Uncle Barry  Offline
U
I have factory 340 bars in my car with a gen 2 hemi between the fenders. Works nice on my street car.
Re: Torsion bars...what do you run? [Re: hemi_doug] #2398783
11/05/17 01:07 PM
11/05/17 01:07 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
And if you would go coil over ? what rate would you go?
Dan
Re: Torsion bars...what do you run? [Re: hemi_doug] #2398859
11/05/17 02:53 PM
11/05/17 02:53 PM
I would and have used six cylinder bars in BB A and B bodies in all of my stock front end drag cars up
A good set of front double adjustable front shocks will help you a lot also up scope
Re: Torsion bars...what do you run? [Re: dvw] #2398875
11/05/17 03:21 PM
11/05/17 03:21 PM
Washington
madscientist Offline
Washington
Doug
Dam that thing looks good. What rear suspension are you using? Not to hijack the thread lol.
Re: Torsion bars...what do you run? [Re: dvw] #2398946
11/05/17 05:53 PM
11/05/17 05:53 PM
Northern N.J.
Northern N.J.
Man that is Awesome! Nice ride!
Re: Torsion bars...what do you run? [Re: hemi_doug] #2398989
11/05/17 06:38 PM
11/05/17 06:38 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Still running the slant six bars that were installed at the factory and they still work pretty good shruggy
Gus beer
64 Plymouth Savoy
Dana 60
Re: Torsion bars...what do you run? [Re: hemi_doug] #2398999
11/05/17 07:02 PM
11/05/17 07:02 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I stil run the factory 383 bars that came in my car. Its an original 383 car and I figured I would try them and they work fine for me. Ron
