Small Block Pushbutton Trans on Big Block??? #2392405
10/24/17 04:30 PM
10/24/17 04:30 PM
Indiana
MFR440 Offline OP
MFR440  Offline OP
Indiana
I have a Poly 318 with Pushbutton 727 and want to use it on a future build 440. Does anyone make an adapter, or is there any way to make it work on a Big Block?
Just thinking out loud....lol
Thanks!
Re: Small Block Pushbutton Trans on Big Block??? [Re: MFR440] #2392426
10/24/17 05:13 PM
10/24/17 05:13 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Have the guts put in a BB case.
Re: Small Block Pushbutton Trans on Big Block??? [Re: slantzilla] #2392480
10/24/17 06:57 PM
10/24/17 06:57 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
He needs a big block push button/cable shift 727 transmission case to use the push button shifter.
It's not just the push button valve body that's needed.
Re: Small Block Pushbutton Trans on Big Block??? [Re: MFR440] #2398223
11/04/17 12:53 AM
11/04/17 12:53 AM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
JW Ultrabell. Cut you sm block bellhousing off and put a JW bell on. Bolts to the pump bolts.
Re: Small Block Pushbutton Trans on Big Block??? [Re: qwkmopardan] #2398266
11/04/17 03:39 AM
11/04/17 03:39 AM
Indiana
MFR440 Offline OP
MFR440  Offline OP
Indiana
Thanks for the ideas, fellas! Hope I trip over a big block case at a swap meet some time. lol
Re: Small Block Pushbutton Trans on Big Block??? [Re: MFR440] #2398273
11/04/17 04:21 AM
11/04/17 04:21 AM
Laveen, Arizona
GTSDart340 Offline
GTSDart340  Offline
Laveen, Arizona
SMR makes an adapter,. No cutting required. It's a spacer plate between the block and trans.
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
Re: Small Block Pushbutton Trans on Big Block??? [Re: MFR440] #2398305
11/04/17 09:15 AM
11/04/17 09:15 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Easy swap, I've done may. Is it a 65 with a slip yoke? Otherwise you'll need a tail shaft and tail housing from a 65. Also upgrade to a 67 and up input shaft and reaction support (or a complete pump) to allow a current spline converter. I have 65 BB complete cores.
Doug
Re: Small Block Pushbutton Trans on Big Block??? [Re: dvw] #2398375
11/04/17 01:23 PM
11/04/17 01:23 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Doug
This is the way most people go
Re: Small Block Pushbutton Trans on Big Block??? [Re: dvw] #2398376
11/04/17 01:29 PM
11/04/17 01:29 PM
I've used the SMR adapter (on another app) & it was a quality piece but I didn't like the added length (1/2" iirc) & the (included) pieces need to deal with that. I also have an unused JB ultrabell adapter (for another app) & I like the looks of it, you cut the current trans bell face off back to the pump bolt & toss it & bolt on the ultrabell in its place & it has the new bolt pattern on the front. You are in effect just reshaping the bell face to match the trans going against another eng type. Not sure if there might be an input shaft alignment issue but I'm sure it has been addressed (by them) if it is a potential.
Re: Small Block Pushbutton Trans on Big Block??? [Re: dvw] #2398866
11/05/17 03:00 PM
11/05/17 03:00 PM
jersey
Spaceman Spiff Offline
jersey
Doug
This is what I did to keep the push buttons in my car.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Small Block Pushbutton Trans on Big Block??? [Re: Spaceman Spiff] #2399105
11/05/17 10:57 PM
11/05/17 10:57 PM
Indiana
MFR440 Offline OP
MFR440  Offline OP
Indiana
The small block trans is a '64. I think one of the BB trans that I have is a '65 - I'll have to check. I am in the planning stages now, so I was just wondering if it was even possible. Thanks for advising the options.
