Mancini Strut Rods_Fit? #2393554
10/26/17 10:37 PM
10/26/17 10:37 PM
People's Republic of Kali
70runner Offline OP
70runner  Offline OP
One of my daughters 69 Charger strut rods was buggered up and bent, so ordered new HD set from Mancini (part #MRE34542 for 66-71 B/E body). So they arrived and I compared them to the originals (and I know they are the originals). The Mancini rods are about 3/4" longer (pix), plus the LCA end does not fit through the LCA mounting cavity.
Anyone with experience with these?
Re: Mancini Strut Rods_Fit? [Re: 70runner] #2393760
10/27/17 11:55 AM
10/27/17 11:55 AM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
I can measure some strut rods that came out of my 67 coronet. Not sure if they are original but they seemed to be the correct length. I had some trouble with the Moog improved design strut rod bushings. There is a metal sleeve in the center and if the doesn't sit in the k-member hole correctly it can push your LCA back.
I actually installed Hotchkis adjustable so that I could get the LCA's exactly where I wanted them. Lower control arms installed and the pivot snugged up, left the torsion bar out, moved the LCA's up to the ride height, moved them forward and adjusted the rods to fit then gave another half turn for some preload.
Check the K-member for any deformation where the strut rod bushings bolt up.
Re: Mancini Strut Rods_Fit? [Re: 70runner] #2393943
10/27/17 07:26 PM
10/27/17 07:26 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
They didn't fit on my 1971 Superbee also
Unless I wanted to bolt them directly to the K Member without the backside bushings
Sucked , they looked nice and I wanted to make them work , but nothing short of a lathe
Anyways returned them for a full refund
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Mancini Strut Rods_Fit? [Re: 70runner] #2393944
10/27/17 07:29 PM
10/27/17 07:29 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
hmm, i would call them and ask what bushings they are designed to be used with.
Re: Mancini Strut Rods_Fit? [Re: 70runner] #2393947
10/27/17 07:29 PM
10/27/17 07:29 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
My factory ones where 17.5" shoulder to shoulder
Mancini was 18"
Siberian Huskies
Re: Mancini Strut Rods_Fit? [Re: 70runner] #2394328
10/28/17 07:08 PM
10/28/17 07:08 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
17.5" for the strut rods off my 67 coronet as well...
Re: Mancini Strut Rods_Fit? [Re: 70runner] #2394360
10/28/17 08:27 PM
10/28/17 08:27 PM
Northwest Indiana
19Coronet66 Offline
19Coronet66  Offline
Northwest Indiana
I just purchased a set of the B body strut rods from Mancini this week. The ones I received from them are exactly like the ones you have. At least a 1/2" longer than the factory stock (68 B Body) strut rods. Haven't tried to install them.
Re: Mancini Strut Rods_Fit? [Re: 70runner] #2394361
10/28/17 08:28 PM
10/28/17 08:28 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
The original poster is saying about 3/4" longer
Mine where 1/2" longer exact
Sounds like a little bit of quality control issue
No way any bushings where going in there unless they where made out of paper
Siberian Huskies
Re: Mancini Strut Rods_Fit? [Re: 70runner] #2394395
10/28/17 09:46 PM
10/28/17 09:46 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
The longer strut rod will KILL caster, by moving the lower control arm back.
Re: Mancini Strut Rods_Fit? [Re: CSK] #2394408
10/28/17 10:06 PM
10/28/17 10:06 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
yeah, I had a combination of weirdly seated Moog improved design strut bushings and a kmember strut rod area that was deformed a bit. It held my LCA on pass side (probably the most common side to take a curb hit) back about 3/8" and I was losing atleast 1.25* caster on that side.
Re: Mancini Strut Rods_Fit? [Re: 70runner] #2395024
10/29/17 08:39 PM
10/29/17 08:39 PM
70runner Offline OP
70runner  Offline OP
Re-measured and the Mancini's are 1/2" longer than stock. The larger diameter of the rod would not fit into the LCA cavity to mate against the mounting lug, so even if it was the correct length it wouldn't work without some machining.
I bought some of these for another B body resto about 5yrs ago and they were correct length and fit perfect. Mancini has obviously changed sources since then.
Re: Mancini Strut Rods_Fit? [Re: 70runner] #2397073
11/01/17 11:29 PM
11/01/17 11:29 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Dropped a note to Mancini regarding this thread, response below
Thanks for the update. We did change vendors and told him to shorten to the
correct length.
Thank you for writing
Rob Cunningham
Mancini Racing
Manciniracing.com
Don't be the exception.
Re: Mancini Strut Rods_Fit? [Re: 70runner] #2397091
11/01/17 11:55 PM
11/01/17 11:55 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Just wonderful
Told me no issues with them over the phone this summer
I guess you have more pull
Siberian Huskies
Re: Mancini Strut Rods_Fit? [Re: 70runner] #2397216
11/02/17 11:02 AM
11/02/17 11:02 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
MoParts has more pull, I just pointed them to the thread and told them they might want to look at it.
Re: Mancini Strut Rods_Fit? [Re: 70runner] #2397288
11/02/17 01:32 PM
11/02/17 01:32 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
can you guys take the bars to a local machinist and have them fixed?
Re: Mancini Strut Rods_Fit? [Re: Supercuda] #2397575
11/02/17 11:18 PM
11/02/17 11:18 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Thank You !
Now do I take another chance on them sending an old pair or updated version
I guess a phone call might answer that question
Siberian Huskies
Re: Mancini Strut Rods_Fit? [Re: 70runner] #2397958
11/03/17 02:59 PM
11/03/17 02:59 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
that's why i would try to have them machined, you will know they are good to go and you can move on to other things.
Re: Mancini Strut Rods_Fit? [Re: 70runner] #2398433
11/04/17 04:48 PM
11/04/17 04:48 PM
BDW Offline
BDW  Offline
Why would you pay to have them machines, I'd hope Mancini would make it right?
