Re: Mancini Strut Rods_Fit?
[Re: 70runner]
#2393943
10/27/17 07:26 PM
10/27/17 07:26 PM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
They didn't fit on my 1971 Superbee also
Unless I wanted to bolt them directly to the K Member without the backside bushings
Sucked , they looked nice and I wanted to make them work , but nothing short of a lathe
Anyways returned them for a full refund
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: 70runner]
#2393947
10/27/17 07:29 PM
10/27/17 07:29 PM
bee1971
Sobieski Wi
My factory ones where 17.5" shoulder to shoulder
Mancini was 18"
[Re: 70runner]
#2394361
10/28/17 08:28 PM
10/28/17 08:28 PM
bee1971
Sobieski Wi
The original poster is saying about 3/4" longer
Mine where 1/2" longer exact
Sounds like a little bit of quality control issue
No way any bushings where going in there unless they where made out of paper
[Re: 70runner]
#2394395
10/28/17 09:46 PM
10/28/17 09:46 PM
Posts: 2,861 Pattison Texas
CSK
Pattison Texas
The longer strut rod will KILL caster, by moving the lower control arm back.
[Re: CSK]
#2394408
10/28/17 10:06 PM
10/28/17 10:06 PM
Posts: 2,094 central texas
krautrock
central texas
The longer strut rod will KILL caster, by moving the lower control arm back. yeah, I had a combination of weirdly seated Moog improved design strut bushings and a kmember strut rod area that was deformed a bit. It held my LCA on pass side (probably the most common side to take a curb hit) back about 3/8" and I was losing atleast 1.25* caster on that side.
[Re: 70runner]
#2397073
11/01/17 11:29 PM
11/01/17 11:29 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Dropped a note to Mancini regarding this thread, response below Thanks for the update. We did change vendors and told him to shorten to the correct length.
Thank you for writing Rob Cunningham Mancini Racing
Manciniracing.com
[Re: 70runner]
#2397091
11/01/17 11:55 PM
11/01/17 11:55 PM
bee1971
Sobieski Wi
Just wonderful
Told me no issues with them over the phone this summer
I guess you have more pull
[Re: 70runner]
#2397216
11/02/17 11:02 AM
11/02/17 11:02 AM
Supercuda
About to go away
About to go away
up yours
MoParts has more pull, I just pointed them to the thread and told them they might want to look at it.
[Re: Supercuda]
#2397575
11/02/17 11:18 PM
11/02/17 11:18 PM
bee1971
Sobieski Wi
Thank You !
Now do I take another chance on them sending an old pair or updated version
I guess a phone call might answer that question
