How to install E body Rally dash switch panel #2395050
10/29/17 09:23 PM
10/29/17 09:23 PM
Rome, Ga
sbhpcb Offline OP
sbhpcb  Offline OP
Rome, Ga
How do you install or rather what order do you install the cuda Rally dash switches so that one does not scratch the wood grain? I have the Gauge cluster in, but the switch panel does not want to wiggle in without hitting the gauge woodgrain?
Re: How to install E body Rally dash switch panel [Re: sbhpcb] #2395708
10/30/17 10:19 PM
10/30/17 10:19 PM
NotRussia
2
2fast4yourBrain Offline
Whack top Dodger
Whack top Dodger
2
NotRussia
Lots of masking tape
Re: How to install E body Rally dash switch panel [Re: 2fast4yourBrain] #2395893
10/31/17 08:17 AM
10/31/17 08:17 AM
Ky
jt4406 Offline
jt4406  Offline
Ky
Maybe you could use a small piece of flashing (readily available at hardware stores and big box construction stores like Lowes). Thin, easily cut with scissors and bent, but substantial enough to protect the woodgrain on your cluster. Just thinking out loud.....
jess
Yeah, it's hopped up to over 160...
Re: How to install E body Rally dash switch panel [Re: sbhpcb] #2395976
10/31/17 12:13 PM
10/31/17 12:13 PM
gtx-guy Offline
gtx-guy  Offline
If you haven't done this yet, loosen your gauge cluster, and slide your switch panel behind the gauge cluster. Make sure you use plenty of masking tape on both panels. I put the tape on my jeans and pulled it off to take off some of the adhesive. Most of all be patient. Good Luck
Re: How to install E body Rally dash switch panel [Re: sbhpcb] #2400681
11/08/17 08:58 PM
11/08/17 08:58 PM
Rome, Ga
sbhpcb Offline OP
sbhpcb  Offline OP
Rome, Ga
Thanks Guys !!! I got it in, but it was hairy.
Re: How to install E body Rally dash switch panel [Re: sbhpcb] #2404460
11/16/17 01:12 PM
11/16/17 01:12 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I always use an old-school, leather chamois when installing side glass, the panel you are referring to and anything else that needs thin, flexible and durable protection. Normally I tape it in place with Gaffers Tape. The 3M stuff the specify for film crews etc. It's awesome and never leaves residue.
