76 833 alum case question #2393590
10/26/17 11:22 PM
10/26/17 11:22 PM
Loganville GA.
K
kdsmith07 Offline OP
K
Loganville GA.
this is dated 76 with vin # 6G164346 but it doesn't have the big o.d.bearing retainer.it uses a 308 and i thought all mopar aluminum cases were o.d.just wondering what it's for.thanks guys
Re: 76 833 alum case question [Re: kdsmith07] #2393621
10/27/17 12:28 AM
10/27/17 12:28 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The 308 IS the big bearing. The standard 23 spline bearing is a 307. Also, the retainer O.D. is much larger on the aluminum cases.
Re: 76 833 alum case question [Re: Stanton] #2393624
10/27/17 12:32 AM
10/27/17 12:32 AM
~5&1/8" iirc
Re: 76 833 alum case question [Re: kdsmith07] #2393667
10/27/17 03:04 AM
10/27/17 03:04 AM
Loganville GA.
K
K
Loganville GA.
this one has the smaller retainer that's 4.7" i think.that's what i don't understand.it doesn't have the 5 1/8 retainer that o.d.'s have.
Re: 76 833 alum case question [Re: kdsmith07] #2393670
10/27/17 03:17 AM
10/27/17 03:17 AM
Loganville GA.
K
K
Loganville GA.
i think what i'm trying to say is i've never had a 76 aluminum case that would accept a regular 4 spd bellhousing.they all needed the truck b.h.
Re: 76 833 alum case question [Re: kdsmith07] #2393673
10/27/17 03:28 AM
10/27/17 03:28 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
The OD bearing retainer and the large (big block/hemi) retainer share the same bolt pattern. My son's A-body 18-spline (home built) uses a '75 iron OD case because the original '68 case had a mounting ear broken off.
Re: 76 833 alum case question [Re: kdsmith07] #2393680
10/27/17 04:10 AM
10/27/17 04:10 AM
Loganville GA.
K
K
Loganville GA.
does he use a regular bellhousing or an o.d.one?
Re: 76 833 alum case question [Re: kdsmith07] #2393745
10/27/17 11:16 AM
10/27/17 11:16 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Do yourself a favor and sell that case for scrap - which it basically is.
1) if its seen average use, the front countershaft hole is going to need to be bushed and should be done on a mill so the hole is bored in the correct location. Even if it were a new case that hole should still be bushed to prevent future problems (they were machined for a floating shaft, not press fit like the iron cases).
2) they don't have anywhere near the strength of an iron case and are prone to the ears breaking of where they bolt to the bell.
Any good tranny guy like Brewers or Passon will tell you to avoid them like the plague. If you're wanting an OD trans, put the guts in an iron case and use a 307 bearing.
Re: 76 833 alum case question [Re: kdsmith07] #2393775
10/27/17 12:35 PM
10/27/17 12:35 PM
Loganville GA.
K
K
Loganville GA.
that's what i needed to know.in the scrap it goes.thanks for all the input guys
Re: 76 833 alum case question [Re: kdsmith07] #2394248
10/28/17 03:32 PM
10/28/17 03:32 PM
USA
rftroy Offline
rftroy  Offline
USA
Good god, don't scrap it!
Give it to someone who can use it.
Robert
AAR 4-speed 3.91, Tor-Red;
70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy;
68 Formula S conv 383 4-speed 3.23, Electric Blue;
69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue;
78 Lil' Red Truck, Red;
70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
Re: 76 833 alum case question [Re: kdsmith07] #2394358
10/28/17 08:23 PM
10/28/17 08:23 PM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
Ha! So all it takes is one person to say scrap it and you are? I have a truck 833od in my desoto street rod. I rebuilt it and did not bush the case. It was fine after I don’t know how many miles before I got it and it’s still going strong.
Re: 76 833 alum case question [Re: kdsmith07] #2394389
10/28/17 09:31 PM
10/28/17 09:31 PM
Loganville GA.
K
K
Loganville GA.
ok,i'll give it to someone who needs it.just don't yell at me
Re: 76 833 alum case question [Re: kdsmith07] #2394445
10/28/17 11:20 PM
10/28/17 11:20 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Use it for what, a planter ?!?! The things are J-U-N-K. Get it out of circulation !!!
Re: 76 833 alum case question [Re: kdsmith07] #2394645
10/29/17 08:24 AM
10/29/17 08:24 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I know someone who will be glad to pay shipping and maybe even a little for your trouble. He has one in a slant six 68 Dart already. He bought it from Passom. Pm your info and I’ll pass along your contact info to my bud.
Re: 76 833 alum case question [Re: kdsmith07] #2394654
10/29/17 09:41 AM
10/29/17 09:41 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I run them in my street cars, no issues. I've even put non OD gut i them and run them because it' easier to benchpress into place.
Chrysler put them into everything for over a decade, most in pickups. If they were junk they would have not kept the aluminum case in production.
I have three of them.
Don't be the exception.
Re: 76 833 alum case question [Re: Stanton] #2394729
10/29/17 12:36 PM
10/29/17 12:36 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
So many parts that we used to take for granted because they were so common, are now getting harder and harder to find. It would be a shame to "junk" something rather than offer it up to see if someone could use it. shruggy
Not everyone races their Mopar, some just drive them.
Master, again and still
Re: 76 833 alum case question [Re: DaveRS23] #2394735
10/29/17 12:41 PM
10/29/17 12:41 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Yep and to add to this, the typical Moparts answer is the money is no object everyone must be a straight line only hardcore drag racer.
Yeah, that's about 2 people on this list with a crap ton of pretenders.
Re: 76 833 alum case question [Re: kdsmith07] #2394774
10/29/17 01:22 PM
10/29/17 01:22 PM
md
mopars4ever Online content
mopars4ever  Online Content
md
Put it in the for sale section for cheap and it would probably sell quick. I`m sure someone would want it.
Re: 76 833 alum case question [Re: kdsmith07] #2395053
10/29/17 09:38 PM
10/29/17 09:38 PM
Loganville GA.
K
K
Loganville GA.
i do have a member here that's interested in it.thanks for all the replys.i'll let you know how it works out.
Re: 76 833 alum case question [Re: kdsmith07] #2395583
10/30/17 07:20 PM
10/30/17 07:20 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Yes it will use a regular BB bellhousing , you said it measured 4.7 ? It can't, the bolt circle would be out past the edge of the retainer.
