dominator flange lo deck M-1 intake #2394013
10/27/17 10:09 PM
10/27/17 10:09 PM
Mt. Vernon, Ohio
dartman366 Offline OP
Mt. Vernon, Ohio
What is the casting numbers on the Dommy flange lo-deck M-1 manifold, going to hit a few swap meets and such this winter and need to make sure I get the right one.
Re: dominator flange lo deck M-1 intake [Re: dartman366] #2394130
10/28/17 03:15 AM
10/28/17 03:15 AM
AndyF Offline
AndyF  Offline
This intake?
Re: dominator flange lo deck M-1 intake [Re: AndyF] #2394259
10/28/17 03:54 PM
10/28/17 03:54 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
Originally Posted By AndyF
This intake?
thats the one, wish I had the cash to take that one off your hands.lol
Re: dominator flange lo deck M-1 intake [Re: dartman366] #2394302
10/28/17 05:42 PM
10/28/17 05:42 PM
tboomer Offline
tboomer  Offline
Buy it Bill! Quit being a tightazz!! grin wave
Re: dominator flange lo deck M-1 intake [Re: dartman366] #2394310
10/28/17 06:10 PM
10/28/17 06:10 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I would like to have it as well. Wrong time of yr for me. Gonna call wilsons next wk and get an idea what they can do with my indy 400-3.
Re: dominator flange lo deck M-1 intake [Re: dartman366] #2394336
10/28/17 07:35 PM
10/28/17 07:35 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Andy has the coolest toys! boogie
Re: dominator flange lo deck M-1 intake [Re: mopar dave] #2394437
10/28/17 11:09 PM
10/28/17 11:09 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
I'm in the same boat Dave, my overtime pays for my toys and I just came off a long summer of none, maybe after the first of the year if it's still available.still would like the casting number or part number for it.
Re: dominator flange lo deck M-1 intake [Re: mopar dave] #2394454
10/28/17 11:34 PM
10/28/17 11:34 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
Wilson told me the LD M1 wasn't as good as the 400-3.
The Indy is taller though.
Don
Re: dominator flange lo deck M-1 intake [Re: cudadon] #2394468
10/28/17 11:49 PM
10/28/17 11:49 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Good to hear. If $800 to fully port is the price i will be sending it in. Nice ride by the way.
Re: dominator flange lo deck M-1 intake [Re: cudadon] #2394567
10/29/17 02:02 AM
10/29/17 02:02 AM
AndyF Offline
AndyF  Offline
Don
That isn't really an apples to apples comparison. The 400-3 is a max wedge intake while the M1 is for standard heads. Here is a shot of the two side by side.
Re: dominator flange lo deck M-1 intake [Re: AndyF] #2394834
10/29/17 02:42 PM
10/29/17 02:42 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
Don
In my case the Indy would be a bit of overkill and a pretty fair size mismatch on the 240's ,Am I correct in my thinking?
Re: dominator flange lo deck M-1 intake [Re: dartman366] #2394952
10/29/17 06:01 PM
10/29/17 06:01 PM
AndyF Offline
AndyF  Offline
You don't want to put a MW intake on 240 heads. That combination would make less power than a good std port intake.
For a budget engine use the Trick Flow intake with the 240 heads. If you have some spare money then send the TF intake to Hughes for their deep port match. If you have plenty of money then send the intake to Wilson or to someone else who knows how to port intakes.
The 4500 intake makes more power for all out racing but there aren't any really good std port 4500 intakes. The M1 is a decent intake but it needs to be ported before it is really good.
The TF intake with a big 4150 carb is probably the best solution for most people. If you already have a Dominator then try the M1 4500 out of the box. If you want to make a lot of power with 240 heads then buy my intake. I've already done the R&D and paid the money to Wilson. You can buy it from me for a lot less than what Wilson will charge you for the same work.
Re: dominator flange lo deck M-1 intake [Re: dartman366] #2394955
10/29/17 06:06 PM
10/29/17 06:06 PM
AndyF Offline
AndyF  Offline
Here is a Wilson ported Trick Flow intake. This is what I'll be running in my Duster. With a 4150 throttle body it should make 650 hp which will be plenty for that car.
Re: dominator flange lo deck M-1 intake [Re: AndyF] #2395342
10/30/17 01:35 PM
10/30/17 01:35 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
Don
I'm sorry I got two different combos mixed up.
Andy you're right not apples to apples.
I was running my 451 ld with stage 6 std port heads. I sent a M1 rb 4150 to Wilson and they told me to find a better manifold. I sent them an edelbrock 2954 (stg6 heads, rb manifold on ld block).
Wilson said that manifold would work for my combo (650 hp)
That was for a drag car, no street use.
The 400-3 is on my 496 with SR max wedge heads.
Sorry for the mix up.
Don
Re: dominator flange lo deck M-1 intake [Re: cudadon] #2395356
10/30/17 01:50 PM
10/30/17 01:50 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
So, you had Wilson port a Victor 440 intake for you? If so, any pics of the work that you can post? And did you ever do a before & after on-track comparison between the stock and ported intake? work
Re: dominator flange lo deck M-1 intake [Re: dartman366] #2395804
10/31/17 12:42 AM
10/31/17 12:42 AM
Alberta,Canada
605ply Offline
605ply  Offline
Alberta,Canada
to answer your original question p4532250-2
Re: dominator flange lo deck M-1 intake [Re: BradH] #2396055
10/31/17 02:34 PM
10/31/17 02:34 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
Brad I will have to look for pics. I will check my logbooks for before and after runs.
The inside looks about the same as the ones Andy posted.
Don
Re: dominator flange lo deck M-1 intake [Re: mopar dave] #2396060
10/31/17 02:38 PM
10/31/17 02:38 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
It's been Feb. 2014 since I had mine done, $1000.
Don
Re: dominator flange lo deck M-1 intake [Re: dartman366] #2396078
10/31/17 03:06 PM
10/31/17 03:06 PM
AndyF Offline
AndyF  Offline
Sounds right. The Mopar intake I have up for sale cost me $1300 for the porting.
Re: dominator flange lo deck M-1 intake [Re: 605ply] #2396306
10/31/17 09:55 PM
10/31/17 09:55 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
Thank you, that is what I wanted to know.now to hit a few indoor swap meets this winter.
