Carb upgrade #2393132
10/25/17 11:03 PM
10/25/17 11:03 PM
Maryland
twayne24365 Offline OP
Maryland
Hi all, I have an 850 double pumper 4781c with choke, I was wondering if there is a good aftermarket hp type main body I could swap in for the benefit of adjustable air bleeds/no choke etc,
Thanks in advance!
Re: Carb upgrade [Re: twayne24365] #2393135
10/25/17 11:08 PM
10/25/17 11:08 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
The Proform's are nice and Summit has em in stock......... thumbs
Re: Carb upgrade [Re: twayne24365] #2393159
10/26/17 12:06 AM
10/26/17 12:06 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
BLP has some nice stuff too.
Re: Carb upgrade [Re: twayne24365] #2393262
10/26/17 10:04 AM
10/26/17 10:04 AM
Maryland
Maryland
Looking on summit I found the pro form main body and Holley offers an up main body for that carb,
The Holley come with 82/82 Jets, doesn’t say what air bleeds
The pro form has 76/84 jets and 33 inner and 73 outer bleeds.
Which would be the better starting point?
Re: Carb upgrade [Re: twayne24365] #2393341
10/26/17 01:28 PM
10/26/17 01:28 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I use both in budget builds and BLP Billet for the top dog stuff..........In your case I'd go w/the Pro-form as that jetting is more street oriented w/the jet spread and primary p/v.......... thumbs
Re: Carb upgrade [Re: twayne24365] #2393398
10/26/17 03:38 PM
10/26/17 03:38 PM
Maryland
Maryland
Thanks thumper, I’ll go with that, one of these days when I get it back in the car I’ll get some updates on it!
Re: Carb upgrade [Re: twayne24365] #2393431
10/26/17 04:48 PM
10/26/17 04:48 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
No problem and let me know if I can help in any way........... thumbs
I have a brand new 850 QF/Holley main body carb I tested on my Dart that you can have for $850 shipped if interested........... beer
Re: Carb upgrade [Re: twayne24365] #2393485
10/26/17 07:13 PM
10/26/17 07:13 PM
Maryland
Maryland
I’ll ask a few of my buddies for ya... next carb I get will be a dominator,
But I’m sure I’ll have a few questions with this one, always had super rich idle problems but I finally got a wideband so I’ll be able to see how my tuning is working lol
I finally got a jet kit now I need some airbleeds and I’ll be able to really tinker with it
Re: Carb upgrade [Re: twayne24365] #2393486
10/26/17 07:13 PM
10/26/17 07:13 PM
Maryland
Maryland
But here’s a first question, would it be benifitial to block off the powervalves?
Re: Carb upgrade [Re: twayne24365] #2393509
10/26/17 08:14 PM
10/26/17 08:14 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
that pro form 850 body has smaller venturi size than your old 850 holley
Re: Carb upgrade [Re: CSK] #2393510
10/26/17 08:23 PM
10/26/17 08:23 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I have to check my notes on the venturi sizes on the PF and the Holley I just got and let ya know but I've used em on fairly stout small-blocks and mild big blocks(not my choice)w/good results. The smaller venturi has it's benefits up to a certain point just as the bigger one does but I agree on a Dominator in most applications making 500+ HP big or small-block.............. thumbs I don't memorize this stuff cos it hurts my brain.......... biggrin
Re: Carb upgrade [Re: twayne24365] #2393525
10/26/17 09:05 PM
10/26/17 09:05 PM
Maryland
Maryland
I know what ya mean lol, it’s a little more than mild, not a full race piece but should be stout, deffinately not the best carb for the motor but it should run ok
Re: Carb upgrade [Re: twayne24365] #2393535
10/26/17 09:34 PM
10/26/17 09:34 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Rather than buy a new body, why not send the one you have to Thumper? It shouldn't cost more money to have him drill and tap the bleeds to accept screw-ins.
What do you think Thumper?
Master, again and still
Re: Carb upgrade [Re: DaveRS23] #2393563
10/26/17 10:47 PM
10/26/17 10:47 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
The down side is the heavy zinc main body and the choke horn although I've done several w/good results I prefer the alum. main bodies and of course BILLET is the shiznit.......... biggrin
Re: Carb upgrade [Re: Thumperdart] #2393900
10/27/17 05:21 PM
10/27/17 05:21 PM
NJ
JCCuda Offline
JCCuda  Offline
NJ
Why not upgrade to a Quick Fuel or Pro Form 950 or 1050 main body? the 850 base plate will work with either.
Re: Carb upgrade [Re: twayne24365] #2393905
10/27/17 05:35 PM
10/27/17 05:35 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Thanks in advance!
If you do decide to do a main body swap...... And your current 4781 body is clean and unmolested....... I'd be interested in it(for the right price of course wink )
Re: Carb upgrade [Re: JCCuda] #2393981
10/27/17 09:13 PM
10/27/17 09:13 PM
Maryland
Maryland
I like the way this sounds, will they be a bolt on deal or will there need to be some machining?
