Re: Carb upgrade
[Re: twayne24365]
#2393431
10/26/17 04:48 PM
10/26/17 04:48 PM
Thumperdart
State of confusion
No problem and let me know if I can help in any way........... I have a brand new 850 QF/Holley main body carb I tested on my Dart that you can have for $850 shipped if interested...........
Re: Carb upgrade
[Re: twayne24365]
#2393509
10/26/17 08:14 PM
10/26/17 08:14 PM
Posts: 2,864 Pattison Texas
CSK
Pattison Texas
that pro form 850 body has smaller venturi size than your old 850 holley
Re: Carb upgrade
[Re: twayne24365]
#2393535
10/26/17 09:34 PM
10/26/17 09:34 PM
Posts: 12,162 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Rather than buy a new body, why not send the one you have to Thumper? It shouldn't cost more money to have him drill and tap the bleeds to accept screw-ins.
What do you think Thumper?
Master, again and still
Re: Carb upgrade
[Re: twayne24365]
#2393905
10/27/17 05:35 PM
10/27/17 05:35 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Hi all, I have an 850 double pumper 4781c with choke, I was wondering if there is a good aftermarket hp type main body I could swap in for the benefit of adjustable air bleeds/no choke etc, Thanks in advance! If you do decide to do a main body swap...... And your current 4781 body is clean and unmolested....... I'd be interested in it(for the right price of course )
Re: Carb upgrade
[Re: JCCuda]
#2393981
10/27/17 09:13 PM
10/27/17 09:13 PM
Posts: 181 Maryland
twayne24365
Maryland
Why not upgrade to a Quick Fuel or Pro Form 950 or 1050 main body? the 850 base plate will work with either. I like the way this sounds, will they be a bolt on deal or will there need to be some machining?
