Re: Small Block Pushbutton Trans on Big Block???
[Re: MFR440]
#2392426
10/24/17 05:13 PM
10/24/17 05:13 PM
Posts: 20,182 Park Forest, IL
slantzilla
Park Forest, IL
Have the guts put in a BB case.
[Re: slantzilla]
#2392480
10/24/17 06:57 PM
10/24/17 06:57 PM
Posts: 10,141 A Red State
SNK-EYZ
A Red State
Have the guts put in a BB case. He needs a big block push button/cable shift 727 transmission case to use the push button shifter. It's not just the push button valve body that's needed.
[Re: MFR440]
#2398273
11/04/17 04:21 AM
11/04/17 04:21 AM
Posts: 1,306 Laveen, Arizona
GTSDart340
Laveen, Arizona
SMR makes an adapter,. No cutting required. It's a spacer plate between the block and trans.
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
[Re: dvw]
#2398375
11/04/17 01:23 PM
11/04/17 01:23 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
Easy swap, I've done may. Is it a 65 with a slip yoke? Otherwise you'll need a tail shaft and tail housing from a 65. Also upgrade to a 67 and up input shaft and reaction support (or a complete pump) to allow a current spline converter. I have 65 BB complete cores. Doug This is the way most people go
[Re: dvw]
#2398376
11/04/17 01:29 PM
11/04/17 01:29 PM
RapidRobert
I've used the SMR adapter (on another app) & it was a quality piece but I didn't like the added length (1/2" iirc) & the (included) pieces need to deal with that. I also have an unused JB ultrabell adapter (for another app) & I like the looks of it, you cut the current trans bell face off back to the pump bolt & toss it & bolt on the ultrabell in its place & it has the new bolt pattern on the front. You are in effect just reshaping the bell face to match the trans going against another eng type. Not sure if there might be an input shaft alignment issue but I'm sure it has been addressed (by them) if it is a potential.
[Re: dvw]
#2398866
11/05/17 03:00 PM
11/05/17 03:00 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
Easy swap, I've done may. Is it a 65 with a slip yoke? Otherwise you'll need a tail shaft and tail housing from a 65. Also upgrade to a 67 and up input shaft and reaction support (or a complete pump) to allow a current spline converter. I have 65 BB complete cores. Doug This is what I did to keep the push buttons in my car.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
