additional exhaust manifold flange for spark plug clearance #2392251
10/24/17 11:46 AM
10/24/17 11:46 AM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
Has anyone tried using an additional exhaust manifold header flange to gain spark plug clearance?
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: additional exhaust manifold flange for spark plug clearance [Re: 68LAR] #2392384
10/24/17 03:35 PM
10/24/17 03:35 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
Not for spark plug clearance, but for exhaust manifold clearance on eddy heads. SB A body. A header flange and longer studs. Worked for me.
best of 11.39 at 117 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: additional exhaust manifold flange for spark plug clearance [Re: 68LAR] #2392529
10/24/17 08:33 PM
10/24/17 08:33 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
What heads and headers are you running Larry ? I'm running Doug's D452 headers and Indy EZ's with Firecore wires and zero issues.
Gus beer
64 Plymouth Savoy
Dana 60
Re: additional exhaust manifold flange for spark plug clearance [Re: 68LAR] #2392555
10/24/17 09:23 PM
10/24/17 09:23 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
On my SB, I use flange adapters to allow std flange headers to work with my W2 pattern: it helps with the 5/8-hex plugs, and also helps clear the booots (Taylor). Doesn't allow 13/16-hex, they still interfere slightly, although less than without the adapters.
On a BB, they might help depending on their shape, which heads & angles you have.
Re: additional exhaust manifold flange for spark plug clearance [Re: 68LAR] #2392682
10/25/17 12:34 AM
10/25/17 12:34 AM
Scatchamatoon
Saskabusa Offline
Saskabusa  Offline
Scatchamatoon
I have. I welded another header flange to the header to move the tubes away from the cross bolts on an Indy block.
1974 Roadrunner
1967 Charger
Re: additional exhaust manifold flange for spark plug clearance [Re: fourgearsavoy] #2392892
10/25/17 01:58 PM
10/25/17 01:58 PM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
Gus beer
Running RPM heads with older style Hooker tuned headers. Current number is 5209. I wasted money purchasing the Accel shorty plugs. They are less than 3/16" shorter. Didn't help at all!!! These headers have separate flanges. I actually have to loosen the #7& #8 flanges to get to the plugs. I wanted to go with the Doug's but they are not a tuned header! TTI was also an option, but I would have had to buy a $300 starter, plus the $700+ for the headers to make them work. Too much $ for my blood. Got what I thought was a good price on a nice set of coated Hookers, but now have issues. May put my old CPPA's back on, even though they aren't a tuned header.
Re: additional exhaust manifold flange for spark plug clearance [Re: 68LAR] #2392944
10/25/17 04:01 PM
10/25/17 04:01 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
Do TTI headers need a specific mini starter or can you use a Dakota 318 2 wheel drive starter? That's the starter I run. It's the size of a mini and costs $80ish
Re: additional exhaust manifold flange for spark plug clearance [Re: FurryStump] #2392964
10/25/17 04:40 PM
10/25/17 04:40 PM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
The 2" tube and larger TTI's need a special starter due to clearance issues. The 1 7/8" and smaller do not. The stock MOPAR mini will work. Mind you, I'm talking a manual transmission with a 143T flywheel. Automatic transmissions are another story....
