Page 5 of 11 1 2 3 4 5 6 7 10 11
Re: test pic 68 turbo dart project [Re: paul69cuda] #2375781
09/24/17 01:49 AM
09/24/17 01:49 AM
davenport iowa
P
paul69cuda Offline OP
P
davenport iowa
okay i figured out how to crop pics to fit here update as of last monday. as you can see frame rails have been cleaned up and are the factory rails full length he is back on it full bore. i will be going back up in a few weeks when it should be a true roller with motor and trans mounted with hot side done.
Re: test pic 68 turbo dart project [Re: paul69cuda] #2375783
09/24/17 01:52 AM
09/24/17 01:52 AM
davenport iowa
P
P
davenport iowa
one more
Re: test pic 68 turbo dart project [Re: paul69cuda] #2387050
10/13/17 09:02 PM
10/13/17 09:02 PM
davenport iowa
P
P
davenport iowa
just got back fro chicago we have alot of work done im very happy
Re: test pic 68 turbo dart project [Re: paul69cuda] #2387051
10/13/17 09:03 PM
10/13/17 09:03 PM
davenport iowa
P
P
davenport iowa
ok my pics are sideways huh?
Re: test pic 68 turbo dart project [Re: paul69cuda] #2387055
10/13/17 09:11 PM
10/13/17 09:11 PM
davenport iowa
P
P
davenport iowa
if this does not work i will try later [img][/img]
Re: test pic 68 turbo dart project [Re: paul69cuda] #2387057
10/13/17 09:15 PM
10/13/17 09:15 PM
davenport iowa
P
P
davenport iowa
more
Re: test pic 68 turbo dart project [Re: paul69cuda] #2387061
10/13/17 09:19 PM
10/13/17 09:19 PM
davenport iowa
P
P
davenport iowa
more
Re: test pic 68 turbo dart project [Re: paul69cuda] #2387062
10/13/17 09:21 PM
10/13/17 09:21 PM
davenport iowa
P
P
davenport iowa
me having fun
Re: test pic 68 turbo dart project [Re: paul69cuda] #2387065
10/13/17 09:22 PM
10/13/17 09:22 PM
davenport iowa
P
P
davenport iowa
more
Re: test pic 68 turbo dart project [Re: paul69cuda] #2387066
10/13/17 09:24 PM
10/13/17 09:24 PM
davenport iowa
P
P
davenport iowa
oh ya the menscers shocks for the rear
Re: test pic 68 turbo dart project [Re: paul69cuda] #2387069
10/13/17 09:29 PM
10/13/17 09:29 PM
In The Hills
jughed Offline
jughed  Offline
In The Hills
looks great, Paul.
fixed....this is easier than holding the monitor sideways apimp
Re: test pic 68 turbo dart project [Re: jughed] #2387071
10/13/17 09:33 PM
10/13/17 09:33 PM
In The Hills
jughed Offline
jughed  Offline
In The Hills
....more up
Re: test pic 68 turbo dart project [Re: jughed] #2387072
10/13/17 09:36 PM
10/13/17 09:36 PM
davenport iowa
P
P
davenport iowa
jughead you are now my pic guy thanks
Re: test pic 68 turbo dart project [Re: paul69cuda] #2387217
10/14/17 04:48 AM
10/14/17 04:48 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
What are the expectations here? IMO you better invest in some top notch safety gear and bring a set of Huggies for the first shots 'cause this thing gonna go like a bullet!
Re: test pic 68 turbo dart project [Re: paul69cuda] #2387284
10/14/17 11:50 AM
10/14/17 11:50 AM
Mo.
racerx Online work
racerx  Online Work
Mo.
Sweet Build up
Re: test pic 68 turbo dart project [Re: paul69cuda] #2387687
10/15/17 12:12 PM
10/15/17 12:12 PM
davenport iowa
P
P
davenport iowa
expetations are in the 5s when all dialed in and tuned this is my goal but a 4.99 would be great in the 1/8. i should have this running 2018 and since i have never run a car with t-brake and a turbo and e.f.i i will be in learning mode all summer i believe. so i will be on 6psi boost to start and yes i will be wearing HUGGIES to start with BUHAHAHAHA. this has been an 8 year project so no seat time since i started so i will be in for a hell of a learning curve for a while. i am waiting to see were aron at fast forward race cars decides to put the 94 mill precision turbo i still will have a few months of assembly when i get it home sometime around christmass.
Re: test pic 68 turbo dart project [Re: paul69cuda] #2387719
10/15/17 01:28 PM
10/15/17 01:28 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
It looks to be a sweet build and you are doing it right. Just remember it's just a car, albeit a really fast car, leave your emotions in the trailer and use your head. You will be fine. You will love letting go of the button! Remember, it's just a switch, not a brake! When I first started and although I've never been faster than about 5.80, I got all geared up, belts and everything, and sat in the car and practiced the burnout routine and the staging/launch routine. For the most part I didn't want to go to the track and look like an idiot and it worked! I still sit in the car in the staging lanes and practice letting go of the button on the practice/delay box feature. And I still look like an idiot sometimes... whistling
Re: test pic 68 turbo dart project [Re: paul69cuda] #2394094
10/28/17 12:28 AM
10/28/17 12:28 AM
davenport iowa
P
P
davenport iowa
bump for plycuda
Re: test pic 68 turbo dart project [Re: paul69cuda] #2421660
12/20/17 11:22 PM
12/20/17 11:22 PM
davenport iowa
P
P
davenport iowa
update [img][/img]
Re: test pic 68 turbo dart project [Re: paul69cuda] #2421671
12/20/17 11:51 PM
12/20/17 11:51 PM
davenport iowa
P
P
davenport iowa
pics are two big or something like that so just one
