GF-5R...Educate me. #2386601
10/12/17 11:38 PM
10/12/17 11:38 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
Seen a couple of these run down the track....What is the difference between clutchless or clutch assisted?
What configuration can be used for street/strip? Is it a 4+1 where 5th is an OD?
Re: GF-5R...Educate me. [Re: Dragula] #2386610
10/12/17 11:55 PM
10/12/17 11:55 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I know little about them but I think you row all 5 gears on the track meaning no OD. They seem like a pretty wicked trans, there was several of them on drag week this year. But holy crap they are expensive.
68 Barracuda Formula S 340
Re: GF-5R...Educeate me. [Re: Bad340fish] #2386678
10/13/17 03:28 AM
10/13/17 03:28 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Our gf5r is clutch assisted with the first four gears being pretty steep and 5th is (always) 1:1. We run a 3.54 gear in the dana to make it highway friendly, especially with a 28-30" tire. Without getting into specifics the SLR ends up about 11.5 and gears 1-4 work out to make the 3.54 effectively a 4.10. Overdrive without the overdive trans if you will. Looking forward to getting it on the road soon.
Re: GF-5R...Educate me. [Re: Bad340fish] #2386685
10/13/17 04:18 AM
10/13/17 04:18 AM
P
PasiR Offline
PasiR  Offline
P
How much?
Re: GF-5R...Educate me. [Re: PasiR] #2386697
10/13/17 08:26 AM
10/13/17 08:26 AM
jersey
Spaceman Spiff Offline
jersey
How much?
http://www.gforceracing.com.au/pdf/TRANSMISSION_PRICE%20LIST.pdf
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: GF-5R...Educate me. [Re: Spaceman Spiff] #2386700
10/13/17 08:36 AM
10/13/17 08:36 AM
P
PasiR Offline
PasiR  Offline
P
How much?
Thanks.
Re: GF-5R...Educate me. [Re: Dragula] #2386703
10/13/17 09:14 AM
10/13/17 09:14 AM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
The difference between the two are the sliders and face plates on 1st thru 4th gears. For street/strip you would use clutch assisted.
On the G-force 5th gear locks the main shaft straight thru 1 : 1, the countershaft is just along for the ride so no od.
Also Liberty has a similar transmission.
http://libertysgears.com/our-products/lsc-transmissions/
Re: GF-5R...Educate me. [Re: Spaceman Spiff] #2386886
10/13/17 02:34 PM
10/13/17 02:34 PM
What does GST mean?
Re: GF-5R...Educate me. [Re: Dragula] #2386902
10/13/17 03:31 PM
10/13/17 03:31 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
THe clutch assist trans needs to be (or should be) unloaded to release it from the gear it is in during the shift process. THis is because of the angle cut on the sides of the dogs, so the torque is holding the slider to the gear. If you yank hard enuff, you can get it to shift, but it is really hard on parts. YOu can unload it with the clutch, or by lifting the throttle, or with an ignition interrupt. These work OK on the street.
I have no experience with a clutchless, but here is how it was explained to me: The clutchless trans has split sliders, with the 2 halves splined together on the same hub so their rpm is always equal, but they are able to move back and forth independently. So when you pull a gear, only 1/2 of the slider moves until it engages the next gear. That instantly speeds up the main shaft (and thus the previous gear) kicking the other half of the slider out of engagement. These are not streetable. ANything less than a full power shift can hang up the 2nd half of the slider. If both are engaged at once, it scatters the trans. Plus they don't stay in gear by themselves unless under power.
Re: GF-5R...Educate me. [Re: Dragula] #2386968
10/13/17 05:31 PM
10/13/17 05:31 PM
MI
68shifter Offline
68shifter  Offline
MI
That pricing can't be correct. It shows stuff has pretty much doubled since I bought my GF4A a couple years back. I think it's in Australian dollars?!
Gforce usually has a lot of trade-ins too. It's worthwhile to call they might have a good used unit on the shelf.
Re: GF-5R...Educate me. [Re: 68shifter] #2387155
10/14/17 12:39 AM
10/14/17 12:39 AM
New Hampshire, USA
O
oldiron Offline
oldiron  Offline
O
New Hampshire, USA
That's Australian dollars, 1 AUD = USD0.72, so 9000 Australian = 6480 US$
Of course shipping etc to down under adds to that. I think if you contact GForce, it will be considerably less. Like Andre says, I think they often have refurbished units.
Many people that have them love them. From what I see, they are work well and easy to work on., Just too many gears for me.
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge
New New Best: 10.56 @129
68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up
https://www.youtube.com/watch?v=T4jDLKwd9Gs
