caltrak and mono leaf. is it worth it?
#238232
02/27/09 07:53 PM
02/27/09 07:53 PM
Posts: 521 somewhereintheswampsofjersey
1swingin
i run a 383 in a street/strip 71 dart. its all steel and has a 4000 stall,3.91 gears,manual valve body,and 26 inch tall tire. its curently running super stock springs. i went a best of an 11.32 at 119 mph with a pathetic 1.64 60 ft. the tires arnt spinning but the suspension isnt working. what should i do? i forgot 2 mention i run an edelbrockcarb. are the secondaries coming in 2 late?
"I aint here on buisness baby,Iam only here for fun"
Re: caltrak and mono leaf. is it worth it?
[Re: 1swingin]
#238233
02/27/09 07:56 PM
02/27/09 07:56 PM
I had very good luck wit them on a 3800 lb 10.5 tire car. they sure made it hook and super consistent...
[Re: 1swingin]
#238238
02/27/09 08:21 PM
02/27/09 08:21 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
Get a holley......easier to tune and designed for racing. Just my humble opinion and I`ve seen a nice difference in performance from the swap.
[Re: Thumperdart]
#238239
02/27/09 08:32 PM
02/27/09 08:32 PM
1swingin
thats how i want mine 2 leave!!!! my mph is a 10 second run but my 60 ft is a 12. clowns 2 the left of me jokers 2 the rignt here i am stuck in the 11s with my dart
[Re: 10sec340]
#238241
02/28/09 10:31 AM
02/28/09 10:31 AM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
If the tires are not spinning your not going to see much gain. But it will for sure not be a step backwards.
68 Barracuda Formula S 340
[Re: dc426]
#238243
02/28/09 11:55 AM
02/28/09 11:55 AM
Posts: 4,975 new jersey usa
11secdart
new jersey usa
IMO you need more gear, I run a 365 ci Dart, runs 11.50s on a throttle stop and my 60fts are low 1.50s with a 4.56 gear. off the stop its gone 10.40 at 126 with a 1.40 60ft with S/S springs and a Pinion snubber and 4.88s on radial slicks. 10.50s on bias slicks and 4.56s. I went to a Cal- Trac/ Mono leaf set-up and lost 3-4 in 60ft. But my 60fts are more consistent. I never got the big gain I expected like high 1.30 60fts, the car leaves differently and is working better though.
