caltrak and mono leaf. is it worth it? #238232
02/27/09 07:53 PM
02/27/09 07:53 PM
somewhereintheswampsofjersey
1swingin Offline OP
1swingin  Offline OP
i run a 383 in a street/strip 71 dart. its all steel and has a 4000 stall,3.91 gears,manual valve body,and 26 inch tall tire. its curently running super stock springs. i went a best of an 11.32 at 119 mph with a pathetic 1.64 60 ft. the tires arnt spinning but the suspension isnt working. what should i do? i forgot 2 mention i run an edelbrockcarb. are the secondaries coming in 2 late?
"I aint here on buisness baby,Iam only here for fun"
Re: caltrak and mono leaf. is it worth it? [Re: 1swingin] #238233
02/27/09 07:56 PM
02/27/09 07:56 PM
I had very good luck wit them on a 3800 lb 10.5 tire car. they sure made it hook and super consistent...
Re: caltrak and mono leaf. is it worth it? [Re: 1swingin] #238234
02/27/09 08:02 PM
02/27/09 08:02 PM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
That stuff works good. I would change the tire to 28" and probably the gears too, but thats me. How efficient is the converter?
Re: caltrak and mono leaf. is it worth it? [Re: EvilB1Dart] #238235
02/27/09 08:08 PM
02/27/09 08:08 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
If your times are consistent, stay with what you have. If not, the caltrac setup will help your consistency on marginal tracks.
Re: caltrak and mono leaf. is it worth it? [Re: 1swingin] #238236
02/27/09 08:10 PM
02/27/09 08:10 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I like em a lot. That does seem like a small tire to me also but I can say that my car didn`t start coming around till I went to cal-tracs and good ft. shocks.
Re: caltrak and mono leaf. is it worth it? [Re: Thumperdart] #238237
02/27/09 08:15 PM
02/27/09 08:15 PM
1swingin Offline OP
1swingin  Offline OP
i forgot 2 mention iam running an edelbrock carb.are the secondaries coming in 2 late?
Re: caltrak and mono leaf. is it worth it? [Re: 1swingin] #238238
02/27/09 08:21 PM
02/27/09 08:21 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Get a holley......easier to tune and designed for racing. Just my humble opinion and I`ve seen a nice difference in performance from the swap.
Re: caltrak and mono leaf. is it worth it? [Re: Thumperdart] #238239
02/27/09 08:32 PM
02/27/09 08:32 PM
1swingin Offline OP
1swingin  Offline OP
thats how i want mine 2 leave!!!! my mph is a 10 second run but my 60 ft is a 12. clowns 2 the left of me jokers 2 the rignt here i am stuck in the 11s with my dart
Re: caltrak and mono leaf. is it worth it? [Re: 1swingin] #238240
02/27/09 09:58 PM
02/27/09 09:58 PM
long beach,ny
10sec340 Offline
10sec340  Offline
long beach,ny
I was going to go for the caltrac set up, then just did some adjustments and..
http://www.youtube.com/watch?v=JdvaSvqo0qA&feature=channel
S.S springs and snubber ,street et radials.all motor , in complete street trim as the same as I drive around town.
real 383 car now 440..
Re: caltrak and mono leaf. is it worth it? [Re: 10sec340] #238241
02/28/09 10:31 AM
02/28/09 10:31 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
If the tires are not spinning your not going to see much gain. But it will for sure not be a step backwards.
68 Barracuda Formula S 340
Re: caltrak and mono leaf. is it worth it? [Re: Bad340fish] #238242
02/28/09 10:37 AM
02/28/09 10:37 AM
Tampa Florida
dc426 Offline
gotta keep'm separated
dc426  Offline
Tampa Florida
Caltracs have made my car much more consistent
DC.
Re: caltrak and mono leaf. is it worth it? [Re: dc426] #238243
02/28/09 11:55 AM
02/28/09 11:55 AM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
IMO you need more gear, I run a 365 ci Dart, runs 11.50s on a throttle stop and my 60fts are low 1.50s with a 4.56 gear. off the stop its gone 10.40 at 126 with a 1.40 60ft with S/S springs and a Pinion snubber and 4.88s on radial slicks. 10.50s on bias slicks and 4.56s. I went to a Cal- Trac/ Mono leaf set-up and lost 3-4 in 60ft. But my 60fts are more consistent. I never got the big gain I expected like high 1.30 60fts, the car leaves differently and is working better though.
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
