LOKAR OIL DIP STICK 528 HEMI #2381361
10/03/17 06:58 PM
10/03/17 06:58 PM
Toronto,Canada
W
wkeggenhoff Offline OP
W
Toronto,Canada
INSTALLED THIS FLEXABLE DIPSTICK WITH TTI HEADERS. tHE DIP STICK IS ROUND. NOT SUR IF ITS ME BUT HARD TO READ OIL LEVEL WHEN YPOU PULL IT OUT. ALMOST LIKE ITS GETTING WIPED OFF. EVEN WITH 5000KMS ON OIL HARD TO SEE LEVEL
ANYONE ELSE HAVE THIS ISSUE WITH THESE DIPSTICKS. WISH IT HAD THE FLAT TYPE OF STICK
THANKS
69 dodge charger,528 Hemi,Keisler TKO 5spd, Mosier 60 rear end
Re: LOKAR OIL DIP STICK 528 HEMI [Re: wkeggenhoff] #2381650
10/04/17 10:35 AM
10/04/17 10:35 AM
an8sec70cuda Offline
Yep, it's a pain in the butt to read it. I actually have a piece of cable that I marked on each end...one mark to put my finger against so I touch it to the top of the tube when I put it in to check. The other shows the full level. Works much better.
When I built my hemi, I bought about 5 different dipsticks and the Lokar/Milodon style braided setup was the only one I got to fit worth a crap.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: LOKAR OIL DIP STICK 528 HEMI [Re: an8sec70cuda] #2381814
10/04/17 02:57 PM
10/04/17 02:57 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Right now I am not running one & would like to. My Mopar Mega block only had a tiny 1/8" NPT where the dipstick goes. Not thinking about it at the time I should have drilled & tapped it for a larger thread to accept some of these larger dipstick fittings.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: LOKAR OIL DIP STICK 528 HEMI [Re: wkeggenhoff] #2381821
10/04/17 03:04 PM
10/04/17 03:04 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
File a flat into the stick.
69 GTX 68 Road Runner
Re: LOKAR OIL DIP STICK 528 HEMI [Re: JERICOGTX] #2381843
10/04/17 04:13 PM
10/04/17 04:13 PM
The Milodon dipstick I have actually does have a flat on the end of the stick, but it's still a PITA to read.
CHIP
Re: LOKAR OIL DIP STICK 528 HEMI [Re: wkeggenhoff] #2382049
10/04/17 08:27 PM
10/04/17 08:27 PM
Big Western Pencilveinya
U
Uncle Barry Offline
Uncle Barry  Offline
U
I bought a cheap chrome dipstick from summit for a RB motor. My lil brother got my tubing bender and tweaked it. Works fairly well. Took ALOT of messing around and that part was probably the most time consuming of my whole hemi swap.
