400 block
#2380304
10/01/17 11:29 PM
10/01/17 11:29 PM
Posts: 8,043 Mt Morris Michigan
mopar dave
Mt Morris Michigan
I found another 400 block as a spare. Not sure if it a disirable block or not. $150. Might get it. Looks like a 75-78 yr. Says its from a police car? What do you guys think? Worth it?
Re: 400 block
[Re: mopar dave]
#2380379
10/02/17 01:24 AM
10/02/17 01:24 AM
Posts: 43,286 Bend,OR USA
Cab_Burge
Have it sonic tested and magnafluxed before committing to buy it If it is good go for it If not, you got off cheap by paying to have it tested first
Re: 400 block
[Re: mopar dave]
#2380392
10/02/17 01:46 AM
10/02/17 01:46 AM
Posts: 680 st.louis,mo.
dart games
st.louis,mo.
they like to freeze crack at the first freeze plug on drivers side,have it magana flux or pressure check
Re: 400 block
[Re: mopar dave]
#2380878
10/02/17 10:20 PM
10/02/17 10:20 PM
dartman366
Mt. Vernon, Ohio
I bought 2 530 blocks only for 200 each and both had really good sonic numbers, 1 was a 75 the other was a 76, used one and keeping the other as garage art.
Re: 400 block
[Re: mopar dave]
#2380934
10/02/17 11:14 PM
10/02/17 11:14 PM
Posts: 326 Alberta
Wookie316
Alberta
I believe my block is a 530 block so far it’s holding together. Made 838 on the dyno. Billet mains.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
Re: 400 block
[Re: mopar dave]
#2381653
10/04/17 10:46 AM
10/04/17 10:46 AM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
Just to add to what everyone has already told you...I'd get it. The price is great. Doesn't matter what year model it is, or what casting number it is, or what it came out of...you won't know if it's a "good" one until you have it sonic checked.
Re: 400 block
[Re: an8sec70cuda]
#2381657
10/04/17 10:52 AM
10/04/17 10:52 AM
mopar dave
Mt Morris Michigan
yep, picked it up last night. its very clean in and out. guy was gonna rebuild it stock and put it in his 69 coronet. might get a sonic tester and check it myself. thanks guys
