I THINK WE`RE ON TO SOMETHING............. #237899
02/27/09 01:53 PM
02/27/09 01:53 PM
State of confusion
Thumperdart Offline OP
State of confusion
If you`ve seen/heard my vid this pig is laying over in high gear.....I checked flash stall yesturday in 3rd and it flashes bet 4000-4500rpm`s so that seems ok. After thinking about it and talking to my machinest,I`m going to check my valve springs and see how they look and (for now) shim em up to get back my pressures since they`re 4+ years old w/LOTS of street miles. Hopefull that`s the reason it`s laying over if not, we`ll try something else. Thankxx 4 listning.
Re: I THINK WE`RE ON TO SOMETHING............. [Re: Thumperdart] #237900
02/27/09 02:02 PM
02/27/09 02:02 PM
port alberni CAN.
BLACKFISH Offline
BLACKFISH  Offline
port alberni CAN.
Just like to say that your car fascinates me. Great to see a budget minded car run so good at the track and on the street. Far more interesting than hearing about the 6 and 7 second so called street cars that can't make a trip to the track without overheating and rocker issues. Keep up the good work 9.80's are in the near future.
Re: I THINK WE`RE ON TO SOMETHING............. [Re: Thumperdart] #237901
02/27/09 02:07 PM
02/27/09 02:07 PM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
I would check the pressure of the valve springs and If Its low I would disgard ,buy, and install a new set! shiming a set of valve springs is just a cheap bandade in my eyes!valve spring are very inexpensive compared to what they can cause for damage!
Re: I THINK WE`RE ON TO SOMETHING............. [Re: Thumperdart] #237902
02/27/09 02:08 PM
02/27/09 02:08 PM
it sure can't hurt to check the springs but, don't you think if they were an issue, you would notice float in 1st and 2nd gear also?
Re: I THINK WE`RE ON TO SOMETHING............. #237903
02/27/09 02:23 PM
02/27/09 02:23 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Ditto...
I would be looking at a fuel supply issue on the big end. I have had it, as well as many of my friends. Pump might say 140gph, yet you will find, it just might not be enough.
I had a 340 car with 3/8" fuel line and such, jetting changes made no difference in mph, car would not climb much past 1/8 in high gear only. It had a holley blue on it. I put a second one inline with the first....From one pump right into the other and up to the carb. I dropped 10 jet sizes, and mph picked up big time.
Re: I THINK WE`RE ON TO SOMETHING............. [Re: Thumperdart] #237904
02/27/09 02:50 PM
02/27/09 02:50 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Do you have a fuel gauge that you can read in high gear?
Sheldon
Re: I THINK WE`RE ON TO SOMETHING............. [Re: Thumperdart] #237905
02/27/09 03:03 PM
02/27/09 03:03 PM
Mo.
racerx Offline
racerx  Offline
Mo.
No proooblem thump.always like 2 read you'r post
Re: I THINK WE`RE ON TO SOMETHING............. #237906
02/27/09 03:18 PM
02/27/09 03:18 PM
State of confusion
State of confusion
I just assumed it mattered more in high gear than down low since the motors loaded most in high gear. It could be fuel related but I figured if I shimmed up the springs and it picked up, then I`d put new springs on+ people have been shimming for years w/out issues. This thing 1/8th miles great that`s ANOTHER reason for my goofy thaughts.
Re: I THINK WE`RE ON TO SOMETHING............. [Re: RUNCHARGER] #237907
02/27/09 03:34 PM
02/27/09 03:34 PM
State of confusion
State of confusion
I do have a guage but, my dumb a$$ didn`t look to see where it was at.
Re: I THINK WE`RE ON TO SOMETHING............. [Re: Thumperdart] #237908
02/27/09 03:35 PM
02/27/09 03:35 PM
Las Vegas NV
moparmanjames Offline
Las Vegas NV
I also think it's a fuel issue, like others have stated, engine load has very little to do with valve float, it's more of an rpm issue and if you are not having issues in the 1/8 then it's almost certainly a fuel issue.
Re: I THINK WE`RE ON TO SOMETHING............. [Re: Thumperdart] #237909
02/27/09 03:59 PM
02/27/09 03:59 PM
OH
TheBlackCar Offline
TheBlackCar  Offline
OH
If you short shift car and ET stays same or improves, replace valve springs. Also, if it has a roller cam, pull cam and look at it, if springs are weak you will see where the lifter is landing on the backside flank.(jumping the lobe) In which case, thats why most people have lifter issues, the wheel splits after a while. As long as you claim the the springs have been in there, they are more than likely shot, unless you back off the rockers when car sits.
As for the fuel possibilities, if you keep throwing jet at the carb to satisfy top end plug reading and the bottom end numbers start to falter, its fuel volume. Good Luck
Re: I THINK WE`RE ON TO SOMETHING............. [Re: TheBlackCar] #237910
02/27/09 04:21 PM
02/27/09 04:21 PM
State of confusion
State of confusion
Thankxx.....I`m no expert by any means and am open to all suggestions. It`s possibly a combinatin of ALL the above as this thing has hundreds of street miles w/open pressures bet 580-600lbs and closed #`s around 260-280. I`ll flow my pump again at the new 9 lbs. and see how long it takes to get a gal.
Re: I THINK WE`RE ON TO SOMETHING............. [Re: Thumperdart] #237911
02/27/09 04:29 PM
02/27/09 04:29 PM
with an adequate pump you don't need 9 lbs of fuel pressure. volume is the key thing. if your raising fuel pressure and the e.t. improves, you need more volume.
raising the pressure is nothing more than a band-aid. 7.5 lbs should me more than enough pressure if you have enough pump and proper sized fuel lines.
Re: I THINK WE`RE ON TO SOMETHING............. #237912
02/27/09 04:33 PM
02/27/09 04:33 PM
Tulsa, Ok
WadeMetzinger Offline
Tulsa, Ok
If it's fuel delivery or shortage and that's what it sounds like to me you better get out of it quick or you'll melt spark plugs and pistons, I speak from experience....
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
Re: I THINK WE`RE ON TO SOMETHING............. [Re: Thumperdart] #237913
02/27/09 05:25 PM
02/27/09 05:25 PM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
hey Thump, for the heck of it, find that torque converter slippage calculator , and punch in your numbers.
Mine came out 13% slippage ... no wonder my car is super lazy on the top end
Re: I THINK WE`RE ON TO SOMETHING............. [Re: 493_DART] #237914
02/27/09 05:49 PM
02/27/09 05:49 PM
State of confusion
State of confusion
I didn`t look at my tach through the stripe so I don`t know where I was at. In the past if I remember correctly, I went 10.13 @ 132+ w/4.11`s at 6800-7000 rpm`s if that helps.
Re: I THINK WE`RE ON TO SOMETHING............. [Re: Thumperdart] #237915
02/27/09 06:02 PM
02/27/09 06:02 PM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
Re: I THINK WE`RE ON TO SOMETHING............. [Re: 493_DART] #237916
02/27/09 06:07 PM
02/27/09 06:07 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
The MPH is right were it suppose to be given the E/T. At least it is on the cars/trucks I have built.
Re: I THINK WE`RE ON TO SOMETHING............. [Re: 493_DART] #237917
02/27/09 06:50 PM
02/27/09 06:50 PM
State of confusion
State of confusion
Punching in my stats gave me 9.79%...... ?
Re: I THINK WE`RE ON TO SOMETHING............. [Re: Thumperdart] #237918
02/28/09 11:30 AM
02/28/09 11:30 AM
Real North Cal.
66er Offline
66er  Offline
Real North Cal.
How's your ignition system. If it is weak it will show you in high gear. How old are your, cap and rotor, wire, and plugs. I had a simullar problem at the March Meet last year. I cleand the reluctor and pick-up coil on my MSD dist. and the problem went away. How is that for a cheap fix
