Tower (HEI) distributor cap, any advantage? #2377667
09/27/17 12:40 PM
09/27/17 12:40 PM
IL
Dart451 Offline OP
Dart451  Offline OP
IL
Looking at buying new set of wires, and trying to decide if there is really any advantage to the hei tower cap over stock. Have a mopar performance distributor.
Plan on going with firecore custom length wire set.
Re: Tower (HEI) distributor cap, any advantage? [Re: Dart451] #2377686
09/27/17 01:11 PM
09/27/17 01:11 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
The conversion cap frees up some room on the cap, as the boots are a lot narrower than the big brass boots. No need to worry if the terminal is making contact onto the cap terminal. Stainless steel dual crimp terminals snap loudly.. Thanks for the opportunity and trust.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: Tower (HEI) distributor cap, any advantage? [Re: Dart451] #2378011
09/27/17 11:22 PM
09/27/17 11:22 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
What I like about the male terminals is you never have to check them between rounds to see if they are all on tight thumbs
Just snap them down when you buy them and forget it.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Tower (HEI) distributor cap, any advantage? [Re: Dart451] #2378189
09/28/17 11:18 AM
09/28/17 11:18 AM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
Tower terminals require only 90deg boots, castle towers you can put straights
JAKES AUTOMOTIVE
Re: Tower (HEI) distributor cap, any advantage? [Re: Dart451] #2378740
09/29/17 11:47 AM
09/29/17 11:47 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Has anyone ever started making a tower cap for the old, steel, Prestolite style distributors?
