Re: Tower (HEI) distributor cap, any advantage?
[Re: Dart451]
#2377686
09/27/17 01:11 PM
09/27/17 01:11 PM
Posts: 12,129 Cleveland
sunroofgtx
Cleveland
The conversion cap frees up some room on the cap, as the boots are a lot narrower than the big brass boots. No need to worry if the terminal is making contact onto the cap terminal. Stainless steel dual crimp terminals snap loudly.. Thanks for the opportunity and trust.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
[Re: Dart451]
#2378011
09/27/17 11:22 PM
09/27/17 11:22 PM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
What I like about the male terminals is you never have to check them between rounds to see if they are all on tight Just snap them down when you buy them and forget it. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: Dart451]
#2378189
09/28/17 11:18 AM
09/28/17 11:18 AM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
Tower terminals require only 90deg boots, castle towers you can put straights
JAKES AUTOMOTIVE
