cam berring replacement? #237722
02/27/09 11:06 AM
02/27/09 11:06 AM
oklahoma city
aintnoredneck Offline OP
oklahoma city
Is there any tricks to replacing the cam berrings in a 318 with out a cam berring tool.
Re: cam berring replacement? [Re: aintnoredneck] #237723
02/27/09 11:13 AM
02/27/09 11:13 AM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
You will have to have the tool to avoid breaking the bearings.
Re: cam berring replacement? [Re: 69Cuda340S] #237724
02/27/09 11:14 AM
02/27/09 11:14 AM
md
mopars4ever Online content
mopars4ever  Online Content
md
Keep um straight, mark the oil holes so they will line up correctly. OOPS sorry read it wrong. I agree you will need the tool. It is hard enough even when using the tool.
Re: cam berring replacement? [Re: mopars4ever] #237725
02/27/09 11:28 AM
02/27/09 11:28 AM
scratchnfotraction Offline
dont see how you could do it with out the tool/driver
how ya gonna them in there?
Re: cam berring replacement? [Re: scratchnfotraction] #237726
02/27/09 11:31 AM
02/27/09 11:31 AM
Southern Oregon
toyotajeep Offline
toyotajeep  Offline
Southern Oregon
I bit the bullet and just bought the tool.
It will likely get used quite a bit over the span of my life so it seemed like a good purchase.
That and I agree, I do not know how you will get it in there without it....
ROB
1989 Dodge Cummins & 1989 Dodge W-250
Re: cam berring replacement? [Re: aintnoredneck] #237727
02/27/09 11:46 AM
02/27/09 11:46 AM
oklahoma city
oklahoma city
Im going to go ahead and buy the tool.
Thanks all
Re: cam berring replacement? [Re: aintnoredneck] #237728
02/27/09 01:26 PM
02/27/09 01:26 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
If this is a one time deal it will be much less $$$ to have some one do it.
Re: cam berring replacement? [Re: MoparforLife] #237729
02/27/09 01:40 PM
02/27/09 01:40 PM
oklahoma city
oklahoma city
I will need it for the 440 im going to build later, so I should just spring for the tool.
Re: cam berring replacement? [Re: aintnoredneck] #237730
02/27/09 02:04 PM
02/27/09 02:04 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
The tool will come in handy for other operations . I use mine for doing bushings in auto and manual transmissions also .
Re: cam berring replacement? [Re: JohnRR] #237731
02/27/09 02:54 PM
02/27/09 02:54 PM
W. Sacto CA. USA
P
phantomx Offline
phantomx  Offline
P
W. Sacto CA. USA
Do a search for "lisle 18000" on the Google and check pricing. I was looking a few weeks ago and found a place that had it for $111.00 vs nearly $200. This is the same model I rented to install my bearings, it works fantastic. It pays to shop around.
Travis..
70 GTX project, orig 440-4, 4 spd, track pack, FC7, stripper/street racer special.
Re: cam berring replacement? [Re: phantomx] #237732
02/27/09 04:17 PM
02/27/09 04:17 PM
It's a bit pricey & you might not use it too much but it's a must have when you R&R those bearings & maybe your parts house rents one which would be the better way to go money wise or if you buy one rent it out to your buddies when their turn comes.
Re: cam berring replacement? [Re: JohnRR] #237733
02/27/09 04:34 PM
02/27/09 04:34 PM
Hey double R, I never thought about using it for the front pump/extension housing bushings as I had always farmed that out to the trans shop, no mas
