Re: My 440 is hurt. bottom end.
[Re: rickraw]
#2375234
09/22/17 10:28 PM
09/22/17 10:28 PM
dartman366
Mt. Vernon, Ohio
sounds too tinny to be a bearing,more like, windage tray? crank scraper?, flex plate cracked or loose crank or converter bolts.
[Re: dartman366]
#2375242
09/22/17 10:45 PM
09/22/17 10:45 PM
Posts: 5,115 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
If it has a crank scraper on the pan that's my bet... It's a very hollow sound...I don't think it's anything crank to rod related... maybe something heavy hitting something thin??? ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif)
...FAFO...
[Re: ForcedInductions]
#2375295
09/23/17 12:46 AM
09/23/17 12:46 AM
Posts: 48 Sudbury, Ontario, Canada
ForcedInductions
ill pop open the inspection plate in the morning, possibly the pan. i hope its the bolts. i don't even recall if i put in grade 8 or 5. as for windage it does have one but if its getting hit must mean something caused it to move or something is loose to hit it. ie rod cap/bearing
#2375428
09/23/17 12:43 PM
09/23/17 12:43 PM
Posts: 1,811 North Dakota
Azzkikrcuda
North Dakota
I would take the oil filter off and cut it open or dump the oil out of it into a clean tray first. Depending on what you see that should tell if it is a bearing or something else before you take it apart.
The only Carbs I care about are under the hood!
[Re: Cab_Burge]
#2375515
09/23/17 03:08 PM
09/23/17 03:08 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
[Re: RSNOMO]
#2375522
09/23/17 03:24 PM
09/23/17 03:24 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I would cut the oil filter open but then again I bought a tool from Summit years ago that makes that job as easy as opening up a can of soup.
#2375543
09/23/17 04:33 PM
09/23/17 04:33 PM
ForcedInductions
all 4 was converter bolts. one was completely out thankfully no damage replaced them all and used red lock tight this time i will hate myself later but what the heck. cheers guys!
i did notice the snout on the starter was cracked and loose but not coming out. c'est la vie
#2375545
09/23/17 04:39 PM
09/23/17 04:39 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Every time a converter bolt goes in my car the bolts are wire wheeled, cleaned in lacquer thinner, and red lock-tite is used. Lock-tite does not like oil
#2375567
09/23/17 05:34 PM
09/23/17 05:34 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
i did notice the snout on the starter was cracked and loose but not coming out. c'est la vie That was a close call with those tc bolts.no leaks is a good thing.
#2375666
09/23/17 08:44 PM
09/23/17 08:44 PM
Thumperdart
State of confusion
i did notice the snout on the starter was cracked and loose but not coming out. c'est la vie Good catch but I'm trippin on stock rockers in a blown motor.......... ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
