Page 4 of 5 1 2 3 4 5
Re: Bought my first 400 Block this Weekend [Re: Thumperdart] #2346547
08/01/17 02:53 AM
08/01/17 02:53 AM
AndyF Offline
AndyF  Offline
I'm guessing that the pushrods bent first, they look like flexy flyers. Once they bent then the lifter just got beat to heck until it broke.
What springs are you running and which pushrods did you have? With a roller cam and big springs I'd use 7/16 pushrods if they'll fit or a super high quality 3/8 pushrod if the 7/16 won't fit.
Re: Bought my first 400 Block this Weekend [Re: fast68plymouth] #2346573
08/01/17 09:09 AM
08/01/17 09:09 AM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
These heads, lifters, rockers, and cam were all used on my 440 a few weeks ago and ran 9.70 at 138.50.....pushrods are new for the low deck. All this stuff already works....trying to figure out what didn't work right is frustrating at the moment.
Re: Bought my first 400 Block this Weekend [Re: AndyF] #2346636
08/01/17 12:37 PM
08/01/17 12:37 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
That's the most likely scenario.
Re: Bought my first 400 Block this Weekend [Re: fast68plymouth] #2346914
08/01/17 09:24 PM
08/01/17 09:24 PM
Dragula Offline OP
Dragula  Offline OP
I am in agreement with that until I learn more I guess.
Re: Bought my first 400 Block this Weekend [Re: fast68plymouth] #2374168
09/20/17 10:16 PM
09/20/17 10:16 PM
Dragula Offline OP
Dragula  Offline OP
Well this update took me a while...But a long story short, it was only the damage in the pictures above. A couple of push rods and a lifter.
All the bearings, oil pump, and oil passages in the block were good and clear with nothing in them. Filter caught all of it from the looks of everything. Double checked a bunch of stuff, and nothing else hurt.
So, the lifters I had were old enough that they warranted replacing, and now the engine is back in the car and running...In hind sight, we should have probably changed the valve springs as well, but I have to leave somthing to do this winter, or I will be bored.
Next outing...This Friday/Saturday.....
So to recap this build....440Source 512 kit with light weight crank option, 10.8:1 compression....680 lift cam and Indy EZ1 heads, unported.
Re: Bought my first 400 Block this Weekend [Re: Dragula] #2374206
09/20/17 11:16 PM
09/20/17 11:16 PM
Alberta
Wookie316 Offline
Wookie316  Offline
Alberta
Nice looking ride.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
Re: Bought my first 400 Block this Weekend [Re: Dragula] #2374226
09/20/17 11:47 PM
09/20/17 11:47 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
It's all a learning curve both good and bad so enjoy the ride and good luck............ beer
Re: Bought my first 400 Block this Weekend [Re: Dragula] #2374317
09/21/17 01:29 AM
09/21/17 01:29 AM
Toronto
mshred Offline
mshred  Offline
Toronto
Awesome! How much more is the lightweight crank option from 440 source?
Re: Bought my first 400 Block this Weekend [Re: mshred] #2374356
09/21/17 07:47 AM
09/21/17 07:47 AM
Dragula Offline OP
Dragula  Offline OP
I think it was $300 and the crank was 6lbs lighter....I like it. Revs very quickly. After driving a 440 of the same cubes, same heads, same compression for 7 years....its noticeable when you touch the gas pedal.
I have another 400 block now that I scored for $300 and I also intend to build a 383/496 stroker with a procharger if my Hemi sells. All of them will get the light weight 4.25 crank.
Re: Bought my first 400 Block this Weekend [Re: Dragula] #2374572
09/21/17 03:34 PM
09/21/17 03:34 PM
It sounds like we now have another Hemiroid motor convert bow up grin
Re: Bought my first 400 Block this Weekend [Re: Cab_Burge] #2374771
09/21/17 10:44 PM
09/21/17 10:44 PM
Dragula Offline OP
Dragula  Offline OP
Well, those darn things just keep me at a disadvantage it seems....Every time I think I have it, another set back.....Even my engine builder sent me a text today about how my Hemi sucks. Thats twice in two weeks in reassembling it that we have encountered issues with it....
On the other hand, the Wedge combo we have come up with has proven fast and fairly low maintenance and lower cost.....Only problem is, the Cuda has Hemi badges on it....But the spare 440/512 short block would really make it run nice......With the right heads and cam.
Re: Bought my first 400 Block this Weekend [Re: Dragula] #2374916
09/22/17 10:30 AM
09/22/17 10:30 AM
an8sec70cuda Offline
With all the problems you've had w/ that hemi, I think it's time for another engine builder.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Bought my first 400 Block this Weekend [Re: an8sec70cuda] #2376016
09/24/17 06:48 PM
09/24/17 06:48 PM
Dragula Offline OP
Dragula  Offline OP
Well, one, the pan that did fit is in pieces. Big stroke, means you need big clearances. Not easy finding stuff that clears 4.75 in a Mopar.
Two, the oil pressure issue, I think, is block related. We have a hell of a time with oil pressure and since day 1, somthing has not been right. I think we need some BGR help though. Left AJ a message. Might even take it down there and see what is up with one of the passages in it...
On a side not, the 400/512 testing results were about the same. Still has a miss in the upper rpm we have now concluded is a bent valve...Still netted a couple of 6.30's with a 1.39 60ft shifting at 5k....
Heads will be coming off this week...I want to do a leak test and see if it shows up somewhere...
Re: Bought my first 400 Block this Weekend [Re: Dragula] #2377420
09/26/17 10:57 PM
09/26/17 10:57 PM
1.5 miles west of Jacksonburg ...
Ohio Joe Offline
Ohio Joe  Offline
This was my second low deck to come apart. Got one more left then it will be on to the aftermarket.
66 Dart GT " Rat Racer"
Re: Bought my first 400 Block this Weekend [Re: Ohio Joe] #2377542
09/27/17 03:59 AM
09/27/17 03:59 AM
Care to share what size, life span and HP levels that made before failing, please work
N/A or power adder also please work
Re: Bought my first 400 Block this Weekend [Re: Ohio Joe] #2377559
09/27/17 08:24 AM
09/27/17 08:24 AM
Sydney,Australia
tex013 Online content
tex013  Online Content
Sydney,Australia
WOW
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Bought my first 400 Block this Weekend [Re: Ohio Joe] #2377570
09/27/17 09:11 AM
09/27/17 09:11 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
You should be glad you were using a factory block in this situation. Why kill an aftermarket block?
I see nothing in that picture saying block failure. Some part of the rotating assembly took that thing out, as it would have with any block.
Re: Bought my first 400 Block this Weekend [Re: TRENDZ] #2377671
09/27/17 12:43 PM
09/27/17 12:43 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Yep totally agree after looking at that pic for a while cos my junk is going on 16 years w/my dumb azz behind the wheel and still going strong along w/the 413 factory crank............. drive
Re: Bought my first 400 Block this Weekend [Re: Dragula] #2377715
09/27/17 02:15 PM
09/27/17 02:15 PM
So. Burlington, Vt.
So. Burlington, Vt.
From the looks of whats visable on the undamaged side of the block, I see no evidence of anything from the rotating assy flailing around.
Re: Bought my first 400 Block this Weekend [Re: fast68plymouth] #2377718
09/27/17 02:21 PM
09/27/17 02:21 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Detination is a killer weather n/a, boost or NOS...............
