Re: EZ EFI No Start condition/ COMM ERROR
[Re: RV2]
#2374775
09/21/17 10:55 PM
09/21/17 10:55 PM
Posts: 12,395 Taxes & Virus's R-US, NY
Dragula
So if it ran good and is now an issue...Check for a loose connection. Probably a ground.
Check with a voltmeter on Ohm setting and see where you have the highest resistance. If all that is good, check positive wires with a test light and wiggle them while testing.
If all my bad advice fails....Call Rich at FastManEFI on here....
[Re: RV2]
#2374965
09/22/17 12:15 PM
09/22/17 12:15 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
COMM ERROR in general refers to network communications. Is there an external control module with a twisted pair buss wires? As stated before, check powers and grounds, but also check anything relative to buss network wiring. Anything that will stop any talking to the rest of the system (ie: throttle bodies) should be suspect. After that, it is usually an internal controller failure. Note: This is all my opinion from my experience as a Level 3 Chrysler Tech and shop foreman.
[image][/image]
[Re: sgcuda]
#2375960
09/24/17 03:54 PM
09/24/17 03:54 PM
Dragula
COMM ERROR in general refers to network communications. Is there an external control module with a twisted pair buss wires? As stated before, check powers and grounds, but also check anything relative to buss network wiring. Anything that will stop any talking to the rest of the system (ie: throttle bodies) should be suspect. After that, it is usually an internal controller failure. Note: This is all my opinion from my experience as a Level 3 Chrysler Tech and shop foreman. An MSD can probably interfere with it as well if its close by or the wires for it are.
