What switch do I need for an idiot oil light? #2373460
09/19/17 06:35 PM
09/19/17 06:35 PM
Ohio
jlatessa Offline OP
jlatessa  Offline OP
Ohio
Had the wrong sending unit on our 440 so dash oil gauge was inoperative,
Put a manual gauge in other galley port until I got the correct unit from E-Berg.
Would like to have a warning light at eye level to possibly save an engine
and need someone's guidance on type of switch and wire diagram if possible.
Thanks, Joe
Re: What switch do I need for an idiot oil light? [Re: jlatessa] #2373465
09/19/17 06:50 PM
09/19/17 06:50 PM
Kirkland, Washington
Pacnorthcuda Offline
You need a standard "idiot" light sender to screw into the block. You then install the light in the dash and feed one terminal from a "run" position hot circuit--you need to find one under the dash, not hard.
The other side of the light goes to the terminal on your new sender.
The light will come on anytime the key is turned to "run" and will go out as soon as oil pressure (usually about 7-10 lbs) causes the circuit in the sender to open.
Re: What switch do I need for an idiot oil light? [Re: jlatessa] #2373481
09/19/17 07:11 PM
09/19/17 07:11 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Also Marshall gauges has a electric gauge that has programmable high, and low settings that will alert you, and a out put just for an idiot light .
Re: What switch do I need for an idiot oil light? [Re: jlatessa] #2373532
09/19/17 08:23 PM
09/19/17 08:23 PM
Ohio
jlatessa Offline OP
jlatessa  Offline OP
Ohio
Thanks guys, I'll do the Pacnorthcuda set-up since it's the easiest
with engine in the car, more room back there for a wrench on the pass. side port.
Joe
