Re: Locked Dizzy and starting ?
[Re: Kindafast]
#2372976
09/18/17 09:52 PM
09/18/17 09:52 PM
Posts: 4,206 New York
polyspheric
New York
Leaving out starter-kickback as solvable: what engine idles better with full advance than partial advance? Engines that idle above 2,000 RPM.
Boffin Emeritus
[Re: Kindafast]
#2373001
09/18/17 10:28 PM
09/18/17 10:28 PM
Posts: 11,590 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
1500 with light springs? The advance is just about all in anyway. Try 800, with a big roller, in gear at 18 degrees initial.
[Re: Kindafast]
#2373211
09/19/17 11:14 AM
09/19/17 11:14 AM
Posts: 13,368 Marion, South Carolina [><]
an8sec70cuda
I've never had an issue cranking my 14.5:1 446" wedge or my 11:1 572" hemi w/ locked out timing. As long as your battery, starter, and the wiring b/t the 2 are good, you should be fine. Glad you found the issue!
Guess everyone running a crank trigger doesn't know how to tune a motor. LOL, gimme a break.
[Re: polyspheric]
#2373246
09/19/17 12:14 PM
09/19/17 12:14 PM
DaytonaTurbo
Manitoba, Canada
Leaving out starter-kickback as solvable: what engine idles better with full advance than partial advance? Engines that idle above 2,000 RPM. What engine idles worse with full advance at idle? Even my stock lo-po 440 idled great with full advance at 700rpm idle when I tried it just for fun.
[Re: Kindafast]
#2373526
09/19/17 08:13 PM
09/19/17 08:13 PM
Posts: 1,927 Seaford, Va
Kindafast
Seaford, Va
Thanks again guy's , I have been racing a long ass time but never thought of the ignition cutoff switch. Duhh LOL . I installed a manual MSD switch this afternoon and it works great. Damn toggle switches all over my car but it works great. I really think the main issue was the battery. It is funny how it still holds 12.7 volts but you can tell it is weak spinning my engine over. I put another high amp battery in it and it spins over great. Everything wears out I guess !!
6.50 @105.26
[Re: 70dusterjohn]
#2373607
09/19/17 10:28 PM
09/19/17 10:28 PM
RapidRobert
How do you wire one to turn over and the ignition switch ? A seperate normally closed switch in series with the ign (blue/yellow ECU main feed wire works for this). Press it to disable the ign/crank with the key/let your thumb off of it while still cranking.
[Re: 540challenger]
#2373667
09/20/17 12:00 AM
09/20/17 12:00 AM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
I run 2 Orbital gel batteries and one is from 07 and still rocks........... off topic. I love my orbital however they are no longer being made. 😨 I heard you can get em on line but never checked......
