Re: Locked Dizzy and starting ? [Re: Kindafast] #2372976
09/18/17 09:52 PM
09/18/17 09:52 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Leaving out starter-kickback as solvable: what engine idles better with full advance than partial advance?
Engines that idle above 2,000 RPM.
Boffin Emeritus
Re: Locked Dizzy and starting ? [Re: Kindafast] #2372993
09/18/17 10:21 PM
09/18/17 10:21 PM
A727Tflite Offline
A727Tflite  Offline
You over simply - depends on trans type, if auto it depends on stall speed, what carburetor name, what camshaft, other factors. My race car idles at 1500 in or out of gear.
To make a blanket statement isn't accurate.
Do I believe a locked distributor is correct for all cars - absolutely not.
To criticize a guy for doing it and saying he doesn't know how to tune is not fair either.
Re: Locked Dizzy and starting ? [Re: Kindafast] #2373001
09/18/17 10:28 PM
09/18/17 10:28 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
1500 with light springs? The advance is just about all in anyway. Try 800, with a big roller, in gear at 18 degrees initial.
Re: Locked Dizzy and starting ? [Re: Kindafast] #2373211
09/19/17 11:14 AM
09/19/17 11:14 AM
an8sec70cuda Offline
I've never had an issue cranking my 14.5:1 446" wedge or my 11:1 572" hemi w/ locked out timing. As long as your battery, starter, and the wiring b/t the 2 are good, you should be fine. Glad you found the issue!
Guess everyone running a crank trigger doesn't know how to tune a motor. LOL, gimme a break.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Locked Dizzy and starting ? [Re: polyspheric] #2373246
09/19/17 12:14 PM
09/19/17 12:14 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
What engine idles worse with full advance at idle? Even my stock lo-po 440 idled great with full advance at 700rpm idle when I tried it just for fun.
Re: Locked Dizzy and starting ? [Re: Kindafast] #2373252
09/19/17 12:20 PM
09/19/17 12:20 PM
st.louis,mo.
dart games Offline
dart games  Offline
st.louis,mo.
most racers spin it over and hit the ignition
Re: Locked Dizzy and starting ? [Re: Kindafast] #2373526
09/19/17 08:13 PM
09/19/17 08:13 PM
Seaford, Va
Kindafast Offline OP
Seaford, Va
Thanks again guy's , I have been racing a long ass time but never thought of the ignition cutoff switch. Duhh LOL . I installed a manual MSD switch this afternoon and it works great. Damn toggle switches all over my car but it works great. I really think the main issue was the battery. It is funny how it still holds 12.7 volts but you can tell it is weak spinning my engine over. I put another high amp battery in it and it spins over great. Everything wears out I guess !!
6.50 @105.26
Re: Locked Dizzy and starting ? [Re: Thumperdart] #2373606
09/19/17 10:28 PM
09/19/17 10:28 PM
NY usa
540challenger Offline
NY usa
Originally Posted By Thumperdart
I run 2 Orbital gel batteries and one is from 07 and still rocks........... biggrin
off topic. I love my orbital however they are no longer being made. 😨
Re: Locked Dizzy and starting ? [Re: 70dusterjohn] #2373607
09/19/17 10:28 PM
09/19/17 10:28 PM
Originally Posted By 70dusterjohn
How do you wire one to turn over and the ignition switch ?
A seperate normally closed switch in series with the ign (blue/yellow ECU main feed wire works for this). Press it to disable the ign/crank with the key/let your thumb off of it while still cranking.
Re: Locked Dizzy and starting ? [Re: 540challenger] #2373667
09/20/17 12:00 AM
09/20/17 12:00 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I heard you can get em on line but never checked......
Re: Locked Dizzy and starting ? [Re: Kindafast] #2373693
09/20/17 12:41 AM
09/20/17 12:41 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
15-1 572, crank trigger at 32 degrees. Cranks with ignition on, starts instantly. Same factory starter for 550 passes.
Doug
