Re: Fired up after a long sleep. Sounded good, then... [Re: stumpy] #2370111
09/13/17 03:26 PM
09/13/17 03:26 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Originally Posted By stumpy
Nothing worse than some yoyo that tightens the oil filter to the point you have to chisel it off to change oil.
That will happen with no lube on the gasket...IMO.
Re: Fired up after a long sleep. Sounded good, then... [Re: calmopar] #2370116
09/13/17 03:34 PM
09/13/17 03:34 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
We're not talking about "big trucks" though, are we?
Over 45 years doing this crap.
Its not rocket surgery.
I have never seen one filter mfg suggest using a filter wrench to install a spin on filter ON A PASSENGER VEHICLE.
Re: Fired up after a long sleep. Sounded good, then... [Re: Supercuda] #2370118
09/13/17 03:35 PM
09/13/17 03:35 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
There are DIRECTIONS??? someplace? work
grin
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Fired up after a long sleep. Sounded good, then... [Re: amxautox] #2370119
09/13/17 03:36 PM
09/13/17 03:36 PM
amxautox Offline
amxautox  Offline
And some people can't turn a filter 3/4 turn by hand. So, use a wrench as needed.
Tom
author unknown
Re: Fired up after a long sleep. Sounded good, then... [Re: amxautox] #2370132
09/13/17 03:55 PM
09/13/17 03:55 PM
Cincinnati, Ohio
Cincinnati, Ohio
Exactly.
When someone says never a wrench needed I think of trucks, excuse me.
Re: Fired up after a long sleep. Sounded good, then... [Re: finn] #2370144
09/13/17 04:13 PM
09/13/17 04:13 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Originally Posted By finn
Double gasket will do that.
Yup. Always check the old filter to make sure the gasket came off with it.
I did that one time when the car was parked on a slight incline. I started it and hopped back out and noticed oil running out from right behind the front tire. Dove back in and shut it off. Big nessy mess to clean up, but didn't hurt the engine.
I was taught to run a film of oil around the rubber sealing ring and hand screw it snug with one hand only.
Re: Fired up after a long sleep. Sounded good, then... [Re: Neil] #2370208
09/13/17 05:30 PM
09/13/17 05:30 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
I was taught to use fresh oil on a new filter gasket.
It's already there when I fill the filter.
Never used the wrench to tighten 'em.
Always needed one to remove 'em.
Only time I had a filter isues was...
You guessed it the old gasket was still there.
I only needed to do that once.
I have mechanical Aptitude.
I can screw up anything.
Re: Fired up after a long sleep. Sounded good, then... [Re: calmopar] #2370315
09/13/17 08:28 PM
09/13/17 08:28 PM
Sioux Falls,South Dakota
fouronthefloor77 Offline
I'm a Toyota forklift tech and I like that the OEM Toyota filters come with plastic over the end of the filter with the right amount of grease. I've never seen that with any other filter manufacturer. I've done plenty of oil changes in my career and hand tight has never failed me for regular automotive. I've also worked on big trucks and I agree they need a little more torque I was a fan of the old strap wrench.
Re: Fired up after a long sleep. Sounded good, then... [Re: calmopar] #2370358
09/13/17 09:59 PM
09/13/17 09:59 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
For automotive / light truck oil changes, I always hand tighten so they are SNUG - probably 3/4 turn after the gasket makes contact. I use a coating of drain oil to lubricate the new gasket. I've also experienced the dreaded double gasket debacle on my old (new) 96 Ram back when it was a couple years old. In the driveway of course. Started it up & heard a gurgling noise & oil streaming onto the ground - shut it off immediately. No problems - just a mess.
Re: Fired up after a long sleep. Sounded good, then... [Re: calmopar] #2370378
09/13/17 10:30 PM
09/13/17 10:30 PM
P
Porter67 Offline
Porter67  Offline
P
Thank god us as a group here are not responsible for world peace.
Id just like to see more pics of that dart!
Re: Fired up after a long sleep. Sounded good, then... [Re: calmopar] #2370623
09/14/17 12:00 PM
09/14/17 12:00 PM
East Bay, N. Cal.
calmopar Offline OP
calmopar  Offline OP
East Bay, N. Cal.
Well my hand-tightening didn't quite work...i am not strong enough I suppose...another 4+ quarts on the ground. Arrgh! Got a K&N with the nut at the top and used a wrench to tighten it up - all is good now except for all the oil in the engine compartment.
I'll take some pics of the Dart - it's an interesting one. All black 69 GTS 383 auto stripe delete. Kind of a factory sleeper.
Trying to enjoy life!
Re: Fired up after a long sleep. Sounded good, then... [Re: calmopar] #2370719
09/14/17 01:50 PM
09/14/17 01:50 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
sounds like the oil pump relief valve is stuck, need to pull it out & clean it out.
Re: Fired up after a long sleep. Sounded good, then... [Re: calmopar] #2370840
09/14/17 05:51 PM
09/14/17 05:51 PM
P
Porter67 Offline
Porter67  Offline
P
Was it knocking prior to the spill?
Re: Fired up after a long sleep. Sounded good, then... [Re: CSK] #2370859
09/14/17 06:38 PM
09/14/17 06:38 PM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
Yeah, something ain't right. I'm not getting into the wrench/no wrench or manufacturers instructions debate, but you don't need to be Hercules to tighten an oil filter sufficiently. If it's dumping oil like that after a good hand tightening, something else is going on. Don't let it ruin your motor! Do you have an oil pressure gauge?
Re: Fired up after a long sleep. Sounded good, then... [Re: Porter67] #2370867
09/14/17 06:52 PM
09/14/17 06:52 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
haha
Me 2
