Head interchange ? #2367915
09/09/17 02:31 PM
09/09/17 02:31 PM
Shelby, Ohio
2
2abodymcodes Offline OP
Shelby, Ohio
Will the heads off a 1992 360 magnum fit on a 1973 318 ?
Re: Head interchange ? [Re: 2abodymcodes] #2367923
09/09/17 03:08 PM
09/09/17 03:08 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Yes, but
valve train is different, from the pushrods up.
Intake bolt pattern is different
You'll have to double check and correct accessory mount alignment.
Don't be the exception.
Re: Head interchange ? [Re: 2abodymcodes] #2367951
09/09/17 04:46 PM
09/09/17 04:46 PM
New Jersey, USA
Y
yella71 Offline
yella71  Offline
Y
New Jersey, USA
yes but as said lots of different stuff valve train push rods,and lifters, also the way the heads are oiled is totally different. do your research its not just a bolt on.
71 challenger convertable, 64 sport fury 383 ci with factory air 99 sebring convertable 89 CTD pup
Re: Head interchange ? [Re: 2abodymcodes] #2367968
09/09/17 05:49 PM
09/09/17 05:49 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Can be done, but usually you're better off to swap in the whole magnum engine. The magnum heads will need different pushrods and lifters. The angle of the intake manifold bolts is different. Guys used to redrill them to accept LA manifolds. These days you can run aftermarket carb/magnum intakes to solve that problem. By the time you do all that you can swap in the whole magnum engine and enjoy the benefits of better compression ratio and moly rings.
Re: Head interchange ? [Re: 2abodymcodes] #2367984
09/09/17 07:07 PM
09/09/17 07:07 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Re: Head interchange ? [Re: John_Kunkel] #2368332
09/10/17 02:46 PM
09/10/17 02:46 PM
Shelby, Ohio
2
Shelby, Ohio
Good info. Thanks
Re: Head interchange ? [Re: John_Kunkel] #2368335
09/10/17 02:54 PM
09/10/17 02:54 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Originally Posted By John_Kunkel
Some of that info is dated and some of the MP part numbers are N/A.
Re: Head interchange ? [Re: DaytonaTurbo] #2368395
09/10/17 05:29 PM
09/10/17 05:29 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
or rebuilt the old LA engine with the Magnum pistons and rings too.
Re: Head interchange ? [Re: NachoRT74] #2368413
09/10/17 06:05 PM
09/10/17 06:05 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
That opens up it's own can of worms. Balance is different and the rod needs narrowed to fit the Magnum piston. be easier to run higher compression LA pistons.
Re: Head interchange ? [Re: 2abodymcodes] #2369536
09/12/17 05:56 PM
09/12/17 05:56 PM
Niwot, CO Formerly denn...
dynorad Offline
dynorad  Offline
The Magnum engine gets you a roller cam as a bonus. You could probably go to a wrecking yard and pick one up that is equipped with fuel injection and find visible crosshatches in the cylinders.
Re: Head interchange ? [Re: dynorad] #2369636
09/12/17 08:21 PM
09/12/17 08:21 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
You'd be hard pressed to find a Magnum that was NOT fuel injected since they all were.
You can also get the 318 and 360 LA's with roller cam provisions.
FWIW the 87 318 I have for my 65 Cuda has visible cross hatches (stock bore) and was neither a Magnum nor fuel injected. The cross hatches are more a case of having moly rings and not because of FI.
Re: Head interchange ? [Re: Supercuda] #2370129
09/13/17 03:51 PM
09/13/17 03:51 PM
dogdays Offline
dogdays  Offline
The 318 from my mother's '86 Fifth Ave. with about 130K miles still had noticeable crosshatch, no ridge, and all the bearings could have been reused.
Yes much of that could be attributed to the factory moly rings.
I believe that another reason is they never developed much cylinder pressure because of the 2-barrel carb, small cam, small heads. Cylinder pressure loads the rings against the cylinder walls. Also these cars were a favorite of the retired set so they weren't driven hard. I know, all you guys are retirees and drive fast, but you weren't likely to go to your Chrysler dealer and order up a Fifth Avenue, preferring something with a little less stodgy appearance.
R.
