Re: Head interchange ?
[Re: 2abodymcodes]
#2367923
09/09/17 03:08 PM
09/09/17 03:08 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Yes, but
valve train is different, from the pushrods up.
Intake bolt pattern is different
You'll have to double check and correct accessory mount alignment.
[Re: 2abodymcodes]
#2367951
09/09/17 04:46 PM
09/09/17 04:46 PM
Posts: 1,406 New Jersey, USA
yella71
New Jersey, USA
yes but as said lots of different stuff valve train push rods,and lifters, also the way the heads are oiled is totally different. do your research its not just a bolt on.
71 challenger convertable, 64 sport fury 383 ci with factory air
99 sebring convertable
89 CTD pup
[Re: John_Kunkel]
#2368335
09/10/17 02:54 PM
09/10/17 02:54 PM
Supercuda
About to go away
About to go away
up yours
Some of that info is dated and some of the MP part numbers are N/A.
[Re: DaytonaTurbo]
#2368395
09/10/17 05:29 PM
09/10/17 05:29 PM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
By the time you do all that you can swap in the whole magnum engine and enjoy the benefits of better compression ratio and moly rings. or rebuilt the old LA engine with the Magnum pistons and rings too.
[Re: NachoRT74]
#2368413
09/10/17 06:05 PM
09/10/17 06:05 PM
Supercuda
About to go away
About to go away
up yours
By the time you do all that you can swap in the whole magnum engine and enjoy the benefits of better compression ratio and moly rings. or rebuilt the old LA engine with the Magnum pistons and rings too. That opens up it's own can of worms. Balance is different and the rod needs narrowed to fit the Magnum piston. be easier to run higher compression LA pistons.
[Re: dynorad]
#2369636
09/12/17 08:21 PM
09/12/17 08:21 PM
Supercuda
About to go away
About to go away
up yours
The Magnum engine gets you a roller cam as a bonus. You could probably go to a wrecking yard and pick one up that is equipped with fuel injection and find visible crosshatches in the cylinders. You'd be hard pressed to find a Magnum that was NOT fuel injected since they all were. You can also get the 318 and 360 LA's with roller cam provisions. FWIW the 87 318 I have for my 65 Cuda has visible cross hatches (stock bore) and was neither a Magnum nor fuel injected. The cross hatches are more a case of having moly rings and not because of FI.
