Re: New product idea?
[Re: AndyF]
#2366654
09/06/17 10:06 PM
09/06/17 10:06 PM
Posts: 4,457 Washington
madscientist
Washington
I'd be into it. I either use ramps or stands and no matter what I'm doing something is always in the way.
[Re: AndyF]
#2366664
09/06/17 10:24 PM
09/06/17 10:24 PM
Posts: 11,726 Portage,michigan
B3422W5
Portage,michigan
Cant say as i can see the value. You have to jack the car around to get it to the exact correct height to line up the studs, then you cant do any brake or rear axle work. Easier to just jack the car up and throw stands under it. Thats just me.
[Re: CTD5.9]
#2366681
09/06/17 10:47 PM
09/06/17 10:47 PM
Posts: 31,074 Oregon
AndyF
would they be drilled for multiple bolt patterns? Sure that is easy to do. Could put 2 or 3 bolt patterns on them without too much trouble.
[Re: jcc]
#2366682
09/06/17 10:51 PM
09/06/17 10:51 PM
AndyF
They are more secure than a regular jackstand since they are bolted to the car. As long a person actually tightens the lug nuts the jackstand can't come off and it can't flip in or out. It could flip around if the car got rear ended by another car, but the same force would knock any car off of jacks.
I've used this design for a long time on my own cars, just never turned it into a product. Here is a set I built 20 years ago for my Coronet.
This picture also shows why they are nice to use. The entire area under the car is open so you can slide under it to work. By having the suspension compressed everything is at ride height and the frame is taking the load as it would with tires on the car.
[Re: B3422W5]
#2366693
09/06/17 11:10 PM
09/06/17 11:10 PM
madscientist
Washington
Cant say as i can see the value. You have to jack the car around to get it to the exact correct height to line up the studs, then you cant do any brake or rear axle work. Easier to just jack the car up and throw stands under it. Thats just me. Why can't you just jack it up a bit higher than you need, bolt on the stand and then lower it to the ground? I certainly like the idea and if it's price point isn't out ravenous I'd buy a set, maybe two sets.
[Re: AndyF]
#2366710
09/06/17 11:52 PM
09/06/17 11:52 PM
Posts: 916 SE Washington
Forest
SE Washington
I like them, probably shipping them would be the hardest part about keeping the cost down? you make a lot of cool stuff! These are cool too, with an adjustable bottom for setting car at ride height.
[Re: madscientist]
#2366718
09/07/17 12:08 AM
09/07/17 12:08 AM
B3422W5
Portage,michigan
Cant say as i can see the value. You have to jack the car around to get it to the exact correct height to line up the studs, then you cant do any brake or rear axle work. Easier to just jack the car up and throw stands under it. Thats just me. Why can't you just jack it up a bit higher than you need, bolt on the stand and then lower it to the ground? I certainly like the idea and if it's price point isn't out ravenous I'd buy a set, maybe two sets. You can. Sure. I just dont see the need , honestly. Jack and jackstands work well enough.
[Re: Forest]
#2366721
09/07/17 12:11 AM
09/07/17 12:11 AM
Posts: 11,694 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I like them, probably shipping them would be the hardest part about keeping the cost down? you make a lot of cool stuff! These are cool too, with an adjustable bottom for setting car at ride height. That's an interesting picture. Never seen any of that for sale anywhere. Working around the tires when doing set-up work at ride height can be a PIA.
[Re: rickraw]
#2366779
09/07/17 02:01 AM
09/07/17 02:01 AM
AndyF
Cool idea Andy. Is there any side to side swaying? No, the car can't move side to side since the plates are bolted to the hubs. You could slide the car sideways if you pushed on it really hard but you would need to be on a smooth surface. The plates I've built for myself are super solid. I can stand on the bumper and bounce the car to check the spring rate or to see how the shocks are working and stuff like that and the jackstands don't move around. You can't really do that with jackstands under the lower control arms since it isn't as secure.
