Paint markings on leaf springs. #2365251
09/04/17 03:43 PM
09/04/17 03:43 PM
BlueRacer69 Offline OP
Hello members. Anyone know the color of the paint daub the factory used on the rear of leaf springs, back where they attach to the shackles. Its a 1969 383 Dart GTS. Also were springs them self painted or left natural most of the time? Thanks for any info.
Re: Paint markings on leaf springs. [Re: BlueRacer69] #2366039
09/05/17 09:14 PM
09/05/17 09:14 PM
Anyone ?
Re: Paint markings on leaf springs. [Re: BlueRacer69] #2366178
09/06/17 12:58 AM
09/06/17 12:58 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
My '69 Barracuda 340 assembled at Hamtramck early November 1968 had unpainted springs. Dart 383s could have been assembled at Hamtramck but had different springs part number wise.
I found black paint on my spring assemblies but later realized it must have been painted by a spring shop where I had an extra leaf installed years ago. The tipoff was black paint on top of and not under the latex markings near the front eye.
Look very carefully for factory latex paint daubs near the front eye from about 9:00 to 12:00 on the left spring (12:00 to 3:00 on the right), and you might find remnants, as that area is mostly protected from road debris and weathering.
My colors were khaki and aqua, but yours should be different.
Re: Paint markings on leaf springs. [Re: BlueRacer69] #2366444
09/06/17 03:20 PM
09/06/17 03:20 PM
Anybody else ? Need your help with this. Thanks.
Re: Paint markings on leaf springs. [Re: BlueRacer69] #2366459
09/06/17 03:49 PM
09/06/17 03:49 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
I have this pair of NOS lower leaf springs 3400894 that check to 70-71 A-body with 340.
They are in natural bare metal with no paint markings on ends or elsewhere other than the stenciled part number 3400894.
They would be however considered over the counter replacement, which may not likely have markings like completely assembled units, if in fact they did.
Re: Paint markings on leaf springs. [Re: BlueRacer69] #2366498
09/06/17 05:22 PM
09/06/17 05:22 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
It varied with the plant, year, drive train combo, and the guy adding them. This is just one example of an 71 A-body built in October 1970, Hamtramk plant, as with many inspection markings, I've never seen any two that were exactly alike. These were factory painted black and the inspection mark was added afterwards.
Demon Black Survivior Leaf Spring Paint.jpg1971 Demon Survovor Las Vegas Bill Sefton Under Carriage (22).JPG
Re: Paint markings on leaf springs. [Re: BlueRacer69] #2366608
09/06/17 08:37 PM
09/06/17 08:37 PM
Washington, MO
hemigeno Offline
hemigeno  Offline
Washington, MO
Originally Posted By BlueRacer69
Anyone know the color of the paint dabs the factory used on the rear of leaf springs, back where they attach to the shackles. Its a 1969 383 Dart GTS.
The document I have shows a single ID paint daub color for 2835056 springs, that being yellow. I don't know if the ID daub would be the same size as other daubs (only half-way across the spring width) or would go all the way across the spring width.
Originally Posted By kentj340
My '69 Barracuda 340...
My colors were khaki and aqua...
The same document calls out green and olive as the ID paint daub colors for 2835132 springs - just different names for the colors you've observed.
Re: Paint markings on leaf springs. [Re: hemigeno] #2366616
09/06/17 08:47 PM
09/06/17 08:47 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
cool
Re: Paint markings on leaf springs. [Re: hemigeno] #2366736
09/07/17 12:42 AM
09/07/17 12:42 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Yes, 2835132 was the number on my factory spring assemblies for 69 Barracuda 340.
Re: Paint markings on leaf springs. [Re: BlueRacer69] #2368115
09/10/17 12:53 AM
09/10/17 12:53 AM
bump.
Re: Paint markings on leaf springs. [Re: BlueRacer69] #2369356
09/12/17 12:52 PM
09/12/17 12:52 PM
Well, I guess I've stumped the panel on this question. shruggy
Re: Paint markings on leaf springs. [Re: BlueRacer69] #2914029
04/23/21 06:15 PM
04/23/21 06:15 PM
BC Canada
O
ogopogo Offline
ogopogo  Offline
O
BC Canada
anyone know the colours for 71 cuda 340 springs 044?
Re: Paint markings on leaf springs. [Re: ogopogo] #2914625
04/25/21 08:52 AM
04/25/21 08:52 AM
Akron, ohio
76orangewagon Offline
Akron, ohio
When I restored my "044" springs I found a yellow and white swipe after soaking them in Evaporust.
Re: Paint markings on leaf springs. [Re: 76orangewagon] #2914957
04/25/21 10:02 PM
04/25/21 10:02 PM
I'm looking for the paint daub color on the rear of leaf spring #2808678. Car is a 69 383 Dart GTS. Can someone please help with this. Thank you.
Re: Paint markings on leaf springs. [Re: BlueRacer69] #2915401
04/26/21 07:29 PM
04/26/21 07:29 PM
BC Canada
O
ogopogo Offline
ogopogo  Offline
O
BC Canada
Quote
thanks !!!! :-)
Re: Paint markings on leaf springs. [Re: BlueRacer69] #2915469
04/26/21 10:20 PM
04/26/21 10:20 PM
I can't believe nobody at this outstanding informational site knows what color paint markings were on the back of leaf springs for a 69 383 Dart GTS.
Re: Paint markings on leaf springs. [Re: BlueRacer69] #2916163
04/28/21 03:13 PM
04/28/21 03:13 PM
I've been asking this question on here for 4 years now. I can't believe no one knows the answer to this.
Re: Paint markings on leaf springs. [Re: BlueRacer69] #2917524
05/01/21 11:38 PM
05/01/21 11:38 PM
So does no one here have a nicely restored 1969 383 Dart GTS. What color are the paint marking on the rear of the leaf springs?
