Re: Ebody vs Bbody pistol grip differences?
[Re: GoodysGotaCuda]
#2365466
09/04/17 10:11 PM
09/04/17 10:11 PM
Posts: 1,481 Outside
thedriver
Outside
I think the shifter beside the e body one in that pic would work perfect for ya.
1973 challenger Dana. 4 speed. Low deck.
[Re: 6bblgt]
#2365513
09/04/17 11:21 PM
09/04/17 11:21 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I think the shifter beside the e body one in that pic would work perfect for ya. The 71-and later B-body bench seat/non console shifter (the next longer one from the E-body in your pic) will make you happy. They also work perfect in A-body cars. I think the '71-'74 B-body w/bench seat or CenterArmRest would be what you're looking for Thanks guys, I think that's the one I am interested in trying. Dan and Scott, is that shifter "straight" off the trans, or does it joggle over to the passengers side? I need to find out if the T56 bolt pattern is the same as an original, the one I have now is from SST and is not a "Hurst".
#2366073
09/05/17 10:16 PM
09/05/17 10:16 PM
Posts: 732 eastern,Ky
70RT Charger
eastern,Ky
I think the shifter beside the e body one in that pic would work perfect for ya. The 71-and later B-body bench seat/non console shifter (the next longer one from the E-body in your pic) will make you happy. They also work perfect in A-body cars. I think the '71-'74 B-body w/bench seat or CenterArmRest would be what you're looking for Thanks guys, I think that's the one I am interested in trying. Dan and Scott, is that shifter "straight" off the trans, or does it joggle over to the passengers side? I need to find out if the T56 bolt pattern is the same as an original, the one I have now is from SST and is not a "Hurst". Same bolt pattern. I sent the SST shifter back and called Hurst and they sent me one.
[Re: 70RT Charger]
#2366141
09/05/17 11:51 PM
09/05/17 11:51 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Thanks,that helps!
