Wilwood pads and rotors #2361599
08/29/17 10:47 AM
08/29/17 10:47 AM
Alberta
Wookie316 Offline OP
Alberta
I'm going to buy a lottery ticket. On my last pass this past weekend something did not feel right in the front. Wasn't sure if a wheel bearing was starting to go or what?
I was able to check it out last night and low and behold real bad spider cracks in each rotor and one of the pads, the material came off. That was the noise I was hearing/feeeling.
They are 11" rotors with 4 piston calipers. They are the drilled and slotted ones. I believe the P/N#'S are 160-7099/160-7100 rotor & 150-8850 BP-10 pads.
Anyone experience this? Should I be using a different material pad? Should I use a non drilled rotor?
Thanks.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
Re: Wilwood pads and rotors [Re: Wookie316] #2361601
08/29/17 11:00 AM
08/29/17 11:00 AM
Colorado Springs, Colorado
Dartthunder340 Offline
Yikes! Following. Glad you are safe! Mine are not drilled and it's probably about time I changed the pads.
Better get inside Ma. Looks like a storm's comin'.
Re: Wilwood pads and rotors [Re: Wookie316] #2361604
08/29/17 11:07 AM
08/29/17 11:07 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
If that 4100 in your sig is the car weight then there is your answer.
I also learned the hard way that you don't let the pads wear very far. Leads to pistons sticking out too far. I've talked to a few that said 1/2 and chuck em.
Re: Wilwood pads and rotors [Re: Wookie316] #2361618
08/29/17 11:34 AM
08/29/17 11:34 AM
Alberta
Alberta
Ok. So I'm fine to replace with what I had then just put pads in sooner?
Need to order today so I have in time for next race. Thanks.
Re: Wilwood pads and rotors [Re: J_BODY] #2362009
08/29/17 10:40 PM
08/29/17 10:40 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Put me on that list Jay
Wookie you might talk to Wilwood and see if another pad type would be better for you
"Just a Bracket car dressed up like a streetcar"
Re: Wilwood pads and rotors [Re: Wookie316] #2362054
08/29/17 11:37 PM
08/29/17 11:37 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Thanks.
That is a lot of heat so maybe you are on them too long and a hotter pad would slow you faster.
Re: Wilwood pads and rotors [Re: Wookie316] #2362106
08/30/17 12:57 AM
08/30/17 12:57 AM
Alberta
Alberta
Where is best to set an adjustable proportion valve? Maybe I have too much front and not enough rear? I have disk on the back and hydroboost as well.
I will see what Wilwood recommends for pad material.
Re: Wilwood pads and rotors [Re: Wookie316] #2362166
08/30/17 07:16 AM
08/30/17 07:16 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
You can get pads and rotors from Speedway. It's your weight thats getting to them. Spider cracks are not uncommon from heat. Mine have done it. Read about the different pad materials. They make many.
Doug
Re: Wilwood pads and rotors [Re: Wookie316] #2362176
08/30/17 08:45 AM
08/30/17 08:45 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Pad material is critical. And I would probably check your brake balance. Look at your rear brakes. If there is minimal wear on pads and rotors, then yes, you might need more pressure towards the rear.
[image][/image]
Re: Wilwood pads and rotors [Re: Wookie316] #2362209
08/30/17 10:43 AM
08/30/17 10:43 AM
an8sec70cuda Offline
Wookie316...we are in the same boat. My car is about 3900 lbs and hard on brakes. Right now I have the same issue w/ my Aerospace front discs and stock 11" rear drums.
I thought I had my car ready to race a few weeks ago until I happened to look at the front rotors. I noticed they were discolored and had a LOT of cracks in them.
BTW...the guy at Aerospace told me that vented and/or crossdilled rotors are not a benefit on a drag or street/strip car. Told me to get the solid rotors. The more surface area you have for the pad to contact, the better. The new pad technology doesn't need to vent gases away from the contact area like the old days. He said they might not look as cool, but will work better.
I really need to upgrade to rear discs.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Wilwood pads and rotors [Re: an8sec70cuda] #2362233
08/30/17 11:16 AM
08/30/17 11:16 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I have frt,rear pro street disc with undrilled vented rotors and they have held up well
Re: Wilwood pads and rotors [Re: Wookie316] #2362240
08/30/17 11:38 AM
08/30/17 11:38 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I made brackets for dual calipers for a hydraulic hand brake as an e-brake
Re: Wilwood pads and rotors [Re: Wookie316] #2362248
08/30/17 11:50 AM
08/30/17 11:50 AM
Alberta
Alberta
One thing I can do is use the 2nd return road instead of the first at the one track I run at. Have to stand on the brakes pretty hard to make first one. May as well save the equipment and use the 2nd one.
Re: Wilwood pads and rotors [Re: Wookie316] #2362255
08/30/17 12:03 PM
08/30/17 12:03 PM
LOL, I don't have a prayer of taking the first one at Darlington unless I click it off at the 1/8.
CHIP
Re: Wilwood pads and rotors [Re: Wookie316] #2362267
08/30/17 12:25 PM
08/30/17 12:25 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
I was talking to Jim bongard, who is the NHRA inspector for our area. He said that the drilled Wilwood vented rotors have had problems breaking up. One of the victims called Wilwood and they said that anything over 140 miles an hour should use a solid rotor not vented.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Wilwood pads and rotors [Re: Wookie316] #2362314
08/30/17 01:49 PM
08/30/17 01:49 PM
Alberta
Alberta
That's what I suspected. That drilled rotors are propably inferior for my application.
Re: Wilwood pads and rotors [Re: Wookie316] #2362350
08/30/17 02:58 PM
08/30/17 02:58 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I hope you can change rotors without changing the hub.
Re: Wilwood pads and rotors [Re: Wookie316] #2362372
08/30/17 03:47 PM
08/30/17 03:47 PM
Alberta
Alberta
Yes. Already apart and waiting for replacements. All good.
Re: Wilwood pads and rotors [Re: Wookie316] #2362383
08/30/17 03:56 PM
08/30/17 03:56 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I will remember that if I ever switch,Thanks.
