Block damage oil passage parting line #5
#2361015
08/28/17 08:26 AM
08/28/17 08:26 AM
Posts: 145 Australia
dodgy
Australia
Hi all, have a small dilemma with my 360 block, the oil passage on #5 in the block that meets with the oil pump passage in the cap has a small piece cracked out of it. Not sure what to do here, do i pull the piece out, clean it up a little and run it, any problems with the bearing or oil leakage? Anyone ever had this problem. please help Will post up some pics.
Re: Block damage oil passage parting line #5
[Re: dodgy]
#2361098
08/28/17 12:28 PM
08/28/17 12:28 PM
Posts: 4,457 Washington
madscientist
Washington
I'm not sure you even have to sleeve it, but yes break the piece off. And if you can sleeve it, that's the best fix.
Just another issue with the bigger mains of the 360.
[Re: dodgy]
#2361120
08/28/17 01:03 PM
08/28/17 01:03 PM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
That small piece is definitely distorting the bearing fitment. See if you can knock it back flush. If so, and it is captured by the main cap, bearing shell and can't fall back into the bolt hole or go anywhere. You can run it with no migration or bearing distortion issues with a very high probability that it will be like that when you pull it apart for the next rebuild.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: madscientist]
#2361220
08/28/17 04:57 PM
08/28/17 04:57 PM
Posts: 25,748 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I'm not sure you even have to sleeve it, but yes break the piece off. That's what I'd do, break off the piece and run it as is.
[Re: jbc426]
#2362825
08/31/17 01:08 PM
08/31/17 01:08 PM
RapidRobert
That small piece is definitely distorting the bearing fitment. See if you can knock it back flush. If so, and it is captured by the main cap, bearing shell and can't fall back into the bolt hole or go anywhere. You can run it with no migration or bearing distortion issues with a very high probability that it will be like that when you pull it apart for the next rebuild. that's what I would do. I caused that by grabbing a mini freeze plug that was a c hair too big. I tapped the broken chunk back into place & no issues
