69 Charger psteering hose fitting leak #2360677
08/27/17 05:20 PM
08/27/17 05:20 PM
Ks
P
pullandrag Offline OP
P
Ks
New power steering pressure hose can't stop the leak,new hose and fitting in gearbox looks fine, I took it off and put a little grease on it no help,also puddles at back of box at steering shaft could the hose leak be from something internal or should I just try another hose$$?I am around these AN 37 degree fittings at work everyday never had one that leaked like this so is it time to have the box rebuilt I work with hydraulics but never been into a automotive steering box two steps backwards jezz
Re: 69 Charger psteering hose fitting leak [Re: pullandrag] #2360703
08/27/17 06:24 PM
08/27/17 06:24 PM
Andrewh Offline
Andrewh  Offline
new box and new hose?
why do you think it is anything but the hose?
also I had one leak under the fitting. That part comes out and has a copper washer under it.
Re: 69 Charger psteering hose fitting leak [Re: pullandrag] #2360978
08/28/17 02:25 AM
08/28/17 02:25 AM
Ks
P
P
Ks
Well it wasn't the hose it was the fitting on the steering box,needed a magnifying glass but has a small ding in it creating a flat spot I was mad so was looking for answers on here outa desperation wrenching 7 days a week sometimes burns me out OK it is a super tight box in a 60 thou mile Daytona so I just need to fix the rear housing leak now not wanting to replace orig box thanks for the reply
