New power steering pressure hose can't stop the leak,new hose and fitting in gearbox looks fine, I took it off and put a little grease on it no help,also puddles at back of box at steering shaft could the hose leak be from something internal or should I just try another hose$$?I am around these AN 37 degree fittings at work everyday never had one that leaked like this so is it time to have the box rebuilt I work with hydraulics but never been into a automotive steering box two steps backwards jezz
