Dynoing a 408 tomorrow; guesses on hp? #2358225
08/22/17 07:05 PM
08/22/17 07:05 PM
gregsdart Offline OP
Magnum 408, EQ heads with 2.02 intakes,flow is 272 cfm at .600. Cam is a Comp MuthrThumper,hyd roller 235/249/107 in at 105, Airgap dual plane, Quick fuel 850 Q carb, 10.1/1 compression, .039 quench, 17/8 dyno headers to start, will tune then switch to TTI 1 5/8 to 1 3/4 with 18 inch x 3 collectors. What do you think it will make?
Re: Dynoing a 408 tomorrow; guesses on hp? [Re: gregsdart] #2358226
08/22/17 07:08 PM
08/22/17 07:08 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
my guess 530hp/500tq.
Re: Dynoing a 408 tomorrow; guesses on hp? [Re: gregsdart] #2358227
08/22/17 07:09 PM
08/22/17 07:09 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
488 hp
Re: Dynoing a 408 tomorrow; guesses on hp? [Re: gregsdart] #2358234
08/22/17 07:18 PM
08/22/17 07:18 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
479
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Dynoing a 408 tomorrow; guesses on hp? [Re: gregsdart] #2358257
08/22/17 07:46 PM
08/22/17 07:46 PM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
480
Re: Dynoing a 408 tomorrow; guesses on hp? [Re: gregsdart] #2358325
08/22/17 10:05 PM
08/22/17 10:05 PM
Ontario, Canada
75DartHang10 Offline
Ontario, Canada
My 410 just put down 401 rwhp. Indy 360-1 heads but they only flow 270@500 & 287@600. Comp cams 236/242@50.compression is supposed to be 11.3:1 runs 94 Oct pump, TTI w2 1 7/8 headers, straight thru mufflers from magnaflow. Hutch 727 trans, probably too big of steel driveshaft I'll change to alum later, and runs thru a strange engineering ford 9 inch 35 spline axles with a spool and 390 gears. 275/65 et radias on weld 15x10 wheels. Qft 750 carb 1 inch spacer.
I was hoping for Alot more..but it is what it is. Heads down flow enough and the cam chosen was too small.
Re: Dynoing a 408 tomorrow; guesses on hp? [Re: gregsdart] #2358326
08/22/17 10:08 PM
08/22/17 10:08 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
500+hp............... beer
Re: Dynoing a 408 tomorrow; guesses on hp? [Re: gregsdart] #2358327
08/22/17 10:11 PM
08/22/17 10:11 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
I'm guessing 419.8
Oh wait...It's that dyno? 485
My bad it's this Dyno. 520
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: Dynoing a 408 tomorrow; guesses on hp? [Re: gregsdart] #2358336
08/22/17 10:28 PM
08/22/17 10:28 PM
Kingman, Az
Scojodak Offline
Scojodak  Offline
Kingman, Az
Building an EFI 408 as we speak. Zero deck, RHS 2.02 heads, 10.7 cr, 236/242 cam @ 108 lsa, single plane intake, Scat rotating assembly. My builder says it should do 500 hp/525 tq. So that's my guess to the OP. Film @ 11:00
Dakota for life!
Re: Dynoing a 408 tomorrow; guesses on hp? [Re: Scojodak] #2358340
08/22/17 10:31 PM
08/22/17 10:31 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Over 400 and under 651.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Dynoing a 408 tomorrow; guesses on hp? [Re: gregsdart] #2358344
08/22/17 10:34 PM
08/22/17 10:34 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
"Bob, I bet $1" seriously I guess 490hp
Re: Dynoing a 408 tomorrow; guesses on hp? [Re: WO23Coronet] #2358348
08/22/17 10:42 PM
08/22/17 10:42 PM
Gainesville Fl
mphsmitch Offline
mphsmitch  Offline
Gainesville Fl
My Magnum 408 that has 2.02 R/T Heads, .242/ .249 @ .050 .600 lift Ultradyne cam,10.3 to 1 comp. Air Gap intake, HP 750 carb. 727 with a 4600 converter made 420 rwhp and has been a best of 11.09 @ 120 mph @ 3520 lbs. Its mild enough to drive and Im pretty happy with it.
90 Dakota 408 CID R/T heads 727 trans 9.5 converter 8.8 rear Pro 275/60 drag radials [email]11.09 @120mph[/email] N/A
Re: Dynoing a 408 tomorrow; guesses on hp? [Re: gregsdart] #2358374
08/22/17 11:34 PM
08/22/17 11:34 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Greg my guess is .....enough to make the other Dart fun to drive
"Just a Bracket car dressed up like a streetcar"
Re: Dynoing a 408 tomorrow; guesses on hp? [Re: gregsdart] #2358391
08/23/17 12:04 AM
08/23/17 12:04 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Greg, what is it going in?
If a 63/66 dart, those tti step headers were a stinker to get in. Torsion bars, everything has to come out. And the oil filter adapter bolt has to be machined smaller. Passenger header has to come off to get that bolt tight. Real stinkers, but once installed...... nice
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Dynoing a 408 tomorrow; guesses on hp? [Re: gregsdart] #2358407
08/23/17 12:51 AM
08/23/17 12:51 AM
1965 dart, but I am using a coilover setup, no torsion bars. I checked the fit on the engine stand, and no problems once I ground off one middle motor mount. Maybe they moved a tube for the adapter?
This Dart has no heater, radio, etc, light weight buckets, Wilwood brakes, and rack and pinion/coilover conversion. 904 trans, 8.8 rear with Ford disc brakes. Any guesses on curb weight?
Re: Dynoing a 408 tomorrow; guesses on hp? [Re: gregsdart] #2358416
08/23/17 01:08 AM
08/23/17 01:08 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
477hp
Re: Dynoing a 408 tomorrow; guesses on hp? [Re: mphsmitch] #2358417
08/23/17 01:08 AM
08/23/17 01:08 AM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
Without the DA, numbers mean nothing.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
Re: Dynoing a 408 tomorrow; guesses on hp? [Re: gregsdart] #2358421
08/23/17 01:11 AM
08/23/17 01:11 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
The torsion bars go right through the tubes. Good you have a rack and coilovers.
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Dynoing a 408 tomorrow; guesses on hp? [Re: gregsdart] #2358424
08/23/17 01:20 AM
08/23/17 01:20 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
495 HP / 505 TQ?
Re: Dynoing a 408 tomorrow; guesses on hp? [Re: 451Mopar] #2358726
08/23/17 07:36 PM
08/23/17 07:36 PM
dogdays Offline
dogdays  Offline
Fearless Prediction:
At standard temp and atmospheric pressure my guess-top dyno says 554hp.
R.
