Dynoing a 408 tomorrow; guesses on hp?
#2358225
08/22/17 07:05 PM
08/22/17 07:05 PM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Magnum 408, EQ heads with 2.02 intakes,flow is 272 cfm at .600. Cam is a Comp MuthrThumper,hyd roller 235/249/107 in at 105, Airgap dual plane, Quick fuel 850 Q carb, 10.1/1 compression, .039 quench, 17/8 dyno headers to start, will tune then switch to TTI 1 5/8 to 1 3/4 with 18 inch x 3 collectors. What do you think it will make?
Re: Dynoing a 408 tomorrow; guesses on hp?
[Re: gregsdart]
#2358327
08/22/17 10:11 PM
08/22/17 10:11 PM
Posts: 1,260 New Mexico
Adobedude
New Mexico
I'm guessing 419.8 Oh wait...It's that dyno? 485
My bad it's this Dyno. 520
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
[Re: gregsdart]
#2358336
08/22/17 10:28 PM
08/22/17 10:28 PM
Posts: 132 Kingman, Az
Scojodak
Kingman, Az
Building an EFI 408 as we speak. Zero deck, RHS 2.02 heads, 10.7 cr, 236/242 cam @ 108 lsa, single plane intake, Scat rotating assembly. My builder says it should do 500 hp/525 tq. So that's my guess to the OP. Film @ 11:00
Dakota for life!
[Re: WO23Coronet]
#2358348
08/22/17 10:42 PM
08/22/17 10:42 PM
Posts: 198 Gainesville Fl
mphsmitch
Gainesville Fl
My Magnum 408 that has 2.02 R/T Heads, .242/ .249 @ .050 .600 lift Ultradyne cam,10.3 to 1 comp. Air Gap intake, HP 750 carb. 727 with a 4600 converter made 420 rwhp and has been a best of 11.09 @ 120 mph @ 3520 lbs. Its mild enough to drive and Im pretty happy with it.
90 Dakota 408 CID R/T heads 727 trans 9.5 converter 8.8 rear Pro 275/60 drag radials [email]11.09 @120mph[/email] N/A
[Re: gregsdart]
#2358374
08/22/17 11:34 PM
08/22/17 11:34 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
Greg my guess is .....enough to make the other Dart fun to drive
"Just a Bracket car dressed up like a streetcar"
[Re: gregsdart]
#2358391
08/23/17 12:04 AM
08/23/17 12:04 AM
Posts: 11,722 Portage,michigan
B3422W5
Portage,michigan
Greg, what is it going in? If a 63/66 dart, those tti step headers were a stinker to get in. Torsion bars, everything has to come out. And the oil filter adapter bolt has to be machined smaller. Passenger header has to come off to get that bolt tight. Real stinkers, but once installed...... nice
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: gregsdart]
#2358407
08/23/17 12:51 AM
08/23/17 12:51 AM
gregsdart
1965 dart, but I am using a coilover setup, no torsion bars. I checked the fit on the engine stand, and no problems once I ground off one middle motor mount. Maybe they moved a tube for the adapter? This Dart has no heater, radio, etc, light weight buckets, Wilwood brakes, and rack and pinion/coilover conversion. 904 trans, 8.8 rear with Ford disc brakes. Any guesses on curb weight?
[Re: mphsmitch]
#2358417
08/23/17 01:08 AM
08/23/17 01:08 AM
Adobedude
New Mexico
My Magnum 408 that has 2.02 R/T Heads, .242/ .249 @ .050 .600 lift Ultradyne cam,10.3 to 1 comp. Air Gap intake, HP 750 carb. 727 with a 4600 converter made 420 rwhp and has been a best of 11.09 @ 120 mph @ 3520 lbs. Its mild enough to drive and Im pretty happy with it. Without the DA, numbers mean nothing.
[Re: gregsdart]
#2358421
08/23/17 01:11 AM
08/23/17 01:11 AM
B3422W5
Portage,michigan
1965 dart, but I am using a coilover setup, no torsion bars. I checked the fit on the engine stand, and no problems once I ground off one middle motor mount. Maybe they moved a tube for the adapter? This Dart has no heater, radio, etc, light weight buckets, Wilwood brakes, and rack and pinion/coilover conversion. 904 trans, 8.8 rear with Ford disc brakes. Any guesses on curb weight? The torsion bars go right through the tubes. Good you have a rack and coilovers.
