Low Compression Piston with it work with a Blower? #235645
02/25/09 08:55 AM
02/25/09 08:55 AM
Danville, NH
Mopar_Mike Offline OP
Danville, NH
I have set of forged flat top 440 .030 pistons. These are old replacement pistons for mid to late 70's 440. They yield around 8.5.1 with a steel gasket and closed chambered head.
Could I use these with a Blower or is there a technology that I am not aware of when it comes to piston use with a Blower. I do not know a lot, if anything when it comes to building a Blown engine.
Thanks.
RS23L7 4-Speed
Re: Low Compression Piston with it work with a Blower? [Re: Mopar_Mike] #235646
02/25/09 08:57 AM
02/25/09 08:57 AM
Colorado
506RR Offline
506RR  Offline
Colorado
They should work great with a blower! With a supercharged application I heard that things such as quench do not matter near as much. I'm sure there are others who will chime in though.
Re: Low Compression Piston with it work with a Blower? [Re: Mopar_Mike] #235647
02/25/09 12:24 PM
02/25/09 12:24 PM
If this is a street motor you should make sure that the piston top are thick enough to with stand detontaion ubnder boost. I'm not familar with that piston number, is it a cast piston or forged? I would not use a cast piston in a blower motor
Re: Low Compression Piston with it work with a Blower? [Re: Cab_Burge] #235648
02/25/09 01:02 PM
02/25/09 01:02 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
just a question regarding this, how thick does the piston top need to be in a blown motor?
sorry if it was a highjack just got a feeling that question may show up anyway
Re: Low Compression Piston with it work with a Blower? [Re: Cab_Burge] #235649
02/25/09 01:11 PM
02/25/09 01:11 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
My 2.2's seen 23 pounds boost on stock cast pistons. However many guys have turned pistons to ashtrays by doing that too.
Re: Low Compression Piston with it work with a Blower? [Re: Cab_Burge] #235650
02/25/09 01:37 PM
02/25/09 01:37 PM
Danville, NH
Danville, NH
They are a forged piston. I think they are 2288. They pre-date TRW's 2266.
RS23L7 4-Speed
Re: Low Compression Piston with it work with a Blower? [Re: Mopar_Mike] #235651
02/25/09 01:45 PM
02/25/09 01:45 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
yup see picture below. stock cast speed pro's 6 psi of boost. I did burn 3 up, my fault I forgot to turn on the eletric fuel pump. put well over 5k on it and countless runs before I sold the car.
Re: Low Compression Piston with it work with a Blower? [Re: Mopar_Mike] #235652
02/25/09 05:04 PM
02/25/09 05:04 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
Thanks.
i would have to say .200 from the top of the piston is safe for the first ring.my comp HT on my piston is 2.050.i have had my pistons out after running 8lbs for 3yrs and there is some color on the side of the piston to .150/.200.my bore is tight at.006 and the top ring gap at .023[hellfire speedpro]my piston thickness just over the rod i would say is .200. i have wiseco K373A3 w/open chamber 346 heads.8.8cr
Re: Low Compression Piston with it work with a Blower? [Re: Mopar_Mike] #235653
02/25/09 06:20 PM
02/25/09 06:20 PM
Muskegon MI
SMRE Performance Offline
Muskegon MI
Thanks.
What blower are you going to use? What kind of fuel? How much horsepower or boost?
Re: Low Compression Piston with it work with a Blower? [Re: SMRE Performance] #235654
02/25/09 10:00 PM
02/25/09 10:00 PM
ELYRIA,OH
ELYRIA,OH
Thanks.
thanks for any help.
Post deleted by Defbob [Re: Mopar_Mike] #235655
02/25/09 10:06 PM
02/25/09 10:06 PM
Re: Low Compression Piston with it work with a Blower? #235656
02/25/09 11:25 PM
02/25/09 11:25 PM
wisconSIN
Blown61 Offline
Blown61  Offline
wisconSIN
I ran those in mine, watch your timming quench or not it will detonate and hammer number 4 main out and spin a rod bearing.
Re: Low Compression Piston with it work with a Blower? [Re: Blown61] #235657
02/26/09 12:05 AM
02/26/09 12:05 AM
Sherwood park, Alberta.
go green Offline
go green  Offline
You already know the answer .
So many people build mix and match bargain engine combos then wonder why they don't work or fail.
Build a engine combination ( especially a supercharged combo )with a goal and result in mind .
If you don't any money you thought you saved will be lost on buying everything twice.
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
