Re: Voltage Regulator changover
[Re: cbusters]
#2355626
08/17/17 07:40 PM
08/17/17 07:40 PM
Posts: 2,864 Pattison Texas
CSK
Pattison Texas
mine fit on my 68 Charger
[Re: cbusters]
#2355679
08/17/17 09:11 PM
08/17/17 09:11 PM
Posts: 5,445 So Cal
Sinitro
So Cal
Are U are aware that most of the replacements for the early VRs are actually electronic not mechanical.. Just my $0.02...
[Re: Sinitro]
#2355684
08/17/17 09:21 PM
08/17/17 09:21 PM
RapidRobert
^^^ agreed, if the parts house "box" reg does not have the easily visible wire wound resistors on the bottom side of it then it is an electronic version which is vastly superior to the old electromechanical (OE) types. If you have a 2 field terminal alt which you would have to have to be swapping in the later "flat" reg with the triangle connector then just ground one of the male alt field terminals to the nearby alt case (or rework the brush holder to ground it for a more aesthetic appearance).
[Re: cbusters]
#2355707
08/17/17 09:50 PM
08/17/17 09:50 PM
RapidRobert
A guy on here mrrandyj used to sell an electronic one with the OE black case for $29 to your door & reportedly there are a brand or two of parts house regs that the OE black cover will fit right on. More info on the alt you have in mind as that is the wild card right now (is it the std big batt terminal/2 male field terminals?)
[Re: cbusters]
#2355735
08/17/17 10:18 PM
08/17/17 10:18 PM
Posts: 21,076 Niles , Ohio
therocks
Niles , Ohio
Just use the stock alt if good with a new style reg.Most the old points type case even covers them.No wires to cut or add just bolt in place of old reg.Ran them in at least 3 cars with the old alts and no problems.Unless you have tons of add ons no need to change alts.Rocky
Chrysler Firepower
[Re: cbusters]
#2355859
08/18/17 02:23 AM
08/18/17 02:23 AM
RapidRobert
It is a Gen III 5.7 2008 truck alternator. I don't know if that is considered a "big batt terminal/2 male field terminals" alternator. a "regular" type alt which I am assuming it is (as far as wireing schematics go) as opposed to a 1 wire alt.
