8 3/4 ring gear thread chaser #2353045
08/13/17 01:25 AM
08/13/17 01:25 AM
Covington Georgia
RV2 Offline OP
RV2  Offline OP
Covington Georgia
Can anybody help me with the correct thread chaser for 8 3/4 ring gears?
A brand and part number would be awesome.
Re: 8 3/4 ring gear thread chaser [Re: RV2] #2353076
08/13/17 03:29 AM
08/13/17 03:29 AM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Well....left hand threads (fine thread) in case you aren't aware. That greatly complicates the issue for a chaser.
I think they are 3/8 but I don't have them at hand to check.
Re: 8 3/4 ring gear thread chaser [Re: RV2] #2353078
08/13/17 03:56 AM
08/13/17 03:56 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
McMaster-Carr has a great selection of left hand taps.
Re: 8 3/4 ring gear thread chaser [Re: RV2] #2353093
08/13/17 06:53 AM
08/13/17 06:53 AM
Australia
Mcode69 Offline
Mcode69  Offline
Australia
Just use an old ring gear bolt, make a few hacksaw cuts lengthway in the threaded area deeper on the end of the bolt and shallower towards the head. This should give the bolt holes a reasonable cleanout.
Re: 8 3/4 ring gear thread chaser [Re: Mcode69] #2353153
08/13/17 12:13 PM
08/13/17 12:13 PM
moparx Offline
moparx  Offline
a very thin, small diameter cutoff wheel on a die grinder works as well for this.
beer
Re: 8 3/4 ring gear thread chaser [Re: RV2] #2353493
08/14/17 09:45 AM
08/14/17 09:45 AM
crlush Offline
crlush  Offline
Thred files work great.
Re: 8 3/4 ring gear thread chaser [Re: RV2] #2353904
08/14/17 10:13 PM
08/14/17 10:13 PM
Keizer, Oregon U.S.A.
E
elmor353 Offline
elmor353  Offline
E
Thread files work great for a stud or a bolt, but I think he's talking about chasing threads in a bolt hole.
Re: 8 3/4 ring gear thread chaser [Re: elmor353] #2353911
08/14/17 10:25 PM
08/14/17 10:25 PM
dogdays Offline
dogdays  Offline
And I'm thinking "Straight, no chaser".
R.
Re: 8 3/4 ring gear thread chaser [Re: dogdays] #2354499
08/15/17 10:28 PM
08/15/17 10:28 PM
Covington Georgia
RV2 Offline OP
RV2  Offline OP
Covington Georgia
Straight preferably, just to clean out the bolt holes.
Re: 8 3/4 ring gear thread chaser [Re: RV2] #2354697
08/16/17 09:35 AM
08/16/17 09:35 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
For stuff like this, I use a small round wire brush made for cleaning female copper pipe before soldering and then blow out the hole with air. That way no worry about damaging the threads.
