Page 1 of 4 1 2 3 4
Doesn't look like I'll be back soon... #2353060
08/13/17 02:31 AM
08/13/17 02:31 AM
Cotati, CA
Dave Hall Offline OP
Cotati, CA
This is what I found.
Re: Doesn't look like I'll be back soon... [Re: Dave Hall] #2353061
08/13/17 02:32 AM
08/13/17 02:32 AM
Cotati, CA
Cotati, CA
Head. 440-1
Re: Doesn't look like I'll be back soon... [Re: Dave Hall] #2353063
08/13/17 02:34 AM
08/13/17 02:34 AM
Cotati, CA
Cotati, CA
Stock block...
Re: Doesn't look like I'll be back soon... [Re: Dave Hall] #2353066
08/13/17 02:42 AM
08/13/17 02:42 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Looks like Detonation effects damage for sure..? Whats the compression and fuel octane combo?
Re: Doesn't look like I'll be back soon... [Re: Dave Hall] #2353067
08/13/17 03:01 AM
08/13/17 03:01 AM
Washington
madscientist Offline
Washington
Weld the head, deck block back at it.
Re: Doesn't look like I'll be back soon... [Re: Sport440] #2353069
08/13/17 03:12 AM
08/13/17 03:12 AM
Cotati, CA
Cotati, CA
That's a good point! I don't know the exact compression as I went from an 88cc chamber to a 72 cc when I put the -1's on it. It was blue printed at 12.9 originally. I was running 116 Sunoco as it was the same price as 114 at the Sonoma pump. I scored a basically free barrell of VP 110. It sure seemed to like the VP fuel better.
I went over the block with a scotch brite wheel and it just has this little etch. I think I'll run it for the last couple races after getting the head fixed. With some better ⛽️!
Re: Doesn't look like I'll be back soon... [Re: Dave Hall] #2353085
08/13/17 04:46 AM
08/13/17 04:46 AM
Cab_Burge Online work
Cab_Burge  Online Work
I had the same thing happen years ago on a set of original 1962/63 max wedge heads on my old bracket car, them dang Perma Toque gaskets melted a deep groove between the #4 and #6 cylinders on the block and heads whiney
I had them both cast iron welded and had to have a shop, Valley Head service, grind both of them flat on their wet surfacing machine thumbs
All the other shops I contacted in SO CA back then said they wouldn't attempt to cut the block or the heads on their surfacing machines shock shruggy
You got really lucky on that block bow up
Re: Doesn't look like I'll be back soon... [Re: Cab_Burge] #2353117
08/13/17 10:16 AM
08/13/17 10:16 AM
illinois
rbkt65 Offline
rbkt65  Offline
illinois
happened to a buddy of mine and then to us. thats why we use victor reintz or cometic. felpros are not good for us. never had another problem with vr or cometics.
Re: Doesn't look like I'll be back soon... [Re: Dave Hall] #2353132
08/13/17 11:28 AM
08/13/17 11:28 AM
Cotati, CA
Cotati, CA
Cometic's this time as I had the Felpro's laying around and never had a problem with them. Until now. Yeah Cab, luck has been good to me with this engine. Although I never really ran it after the problem occurred. Just enough to find out it wasn't ignition related. Plugs actually came out first this time and really told the whole story.
Re: Doesn't look like I'll be back soon... [Re: Dave Hall] #2353133
08/13/17 11:30 AM
08/13/17 11:30 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Fel-Pros suck!
Cometics here and zero issues!
Re: Doesn't look like I'll be back soon... [Re: Dave Hall] #2353136
08/13/17 11:36 AM
08/13/17 11:36 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Fill the groove with JB weld and hand file flat. Get the head fixed. Use something other than Felpro. Run it. When I was burning up Felpro gaskets, I called them. They told me that their perma-torque and race gaskets both hold to a max of 12:1 compression. At the time, I changed over to the orange gaskets from Dvorjak racing out of Florida. Never had a problem again, until I started cracking 915 castings.
[image][/image]
Re: Doesn't look like I'll be back soon... [Re: Dave Hall] #2353137
08/13/17 11:36 AM
08/13/17 11:36 AM
Cotati, CA
Cotati, CA
I don't know that they actually suck. They went nearly 5 years and won a division championship. I think I was just a little too hard on the beaver Ward. Yes Cometic is a better product.
Re: Doesn't look like I'll be back soon... [Re: Dave Hall] #2353183
08/13/17 01:10 PM
08/13/17 01:10 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
17059 Fel-pro Marine gaskets forever at just 12.1.1 and even reused em after a Pettis dyno session years ago..........do you run a wide band to verify/compare plug readings too............ thumbs
Re: Doesn't look like I'll be back soon... [Re: Dave Hall] #2353188
08/13/17 01:38 PM
08/13/17 01:38 PM
Cotati, CA
Cotati, CA
No O2's. Dom, do you know what the compression might be if it was 12.9 with an 88cc and changed to a 72cc chamber? Know any mathematicians?
Re: Doesn't look like I'll be back soon... [Re: Dave Hall] #2353191
08/13/17 01:43 PM
08/13/17 01:43 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Lots of math guys on here can answer that but I would think it would jump a bunch........you NEED a wb my man........... beer
Re: Doesn't look like I'll be back soon... [Re: Dave Hall] #2353199
08/13/17 02:02 PM
08/13/17 02:02 PM
Plug your engine specs. into United Machine(KB) on line compression calculator with both size CC and see the results scope
Probably around 15.+ to 1 work
Re: Doesn't look like I'll be back soon... [Re: Dave Hall] #2353205
08/13/17 02:09 PM
08/13/17 02:09 PM
Idaho
LaRoy Engines Offline
Idaho
Yep, I get 15.6:1
Re: Doesn't look like I'll be back soon... [Re: Dave Hall] #2353233
08/13/17 03:02 PM
08/13/17 03:02 PM
Cotati, CA
Cotati, CA
Thanks guys! Wow! That much? Time for Q16...I've been meaning to do it for awhile now, might as well bite the bullet...Piston to valve is better than .120, time for a .027 gasket and way more cam... drive
Re: Doesn't look like I'll be back soon... [Re: Dave Hall] #2353239
08/13/17 03:11 PM
08/13/17 03:11 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
If you're going to Q you better have the carb specked and sized for it.............
Re: Doesn't look like I'll be back soon... [Re: Dave Hall] #2353261
08/13/17 03:50 PM
08/13/17 03:50 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
I don't know how aggressive you are with your Scotch-Brite wheel but ANY removal of material in this area of the deck lessens the torque applied to the gasket in this critical area. Remember that if the issue reoccurs.
Just an FYI for anybody cleaning deck surfaces in general.
Personally I'll choose a razor blade, solvent and a rag to clean the deck surface. If it shines like new.... you removed material. Scotch-Brite has no business around an engine anyway.
Page 1 of 4 1 2 3 4
