Re: Doesn't look like I'll be back soon...
[Re: Dave Hall]
#2353297
08/13/17 05:46 PM
08/13/17 05:46 PM
Posts: 9,883 MI, usa
dvw
MI, usa
Not the first time I've seen this. Usually iron heads at 40-42 degrees timing. It is detonation. I'll bet between cylinders 4/6 or 3/5? More heat there with the paired exhaust ports. No gasket will withstand detonation forever. 15.9-1 needs a decent gasket for sure. The real question is what caused the detonation? How much timing? How much cam timing? How is the oil control in the cylinder? How do the rod bearings look? For what its worth my 572, -1, runs 15-1 on Renegade 114 , Cometics, studs, 32 degrees, 285@.050, 112LCA in at 108. Never an issue. Reused the gaskets 3 times, 450 passes. Doug
[Re: Dave Hall]
#2353369
08/13/17 10:20 PM
08/13/17 10:20 PM
Posts: 31,082 Oregon
AndyF
Thanks guys! Wow! That much? Time for Q16...I've been meaning to do it for awhile now, might as well bite the bullet...Piston to valve is better than .120, time for a .027 gasket and way more cam... Do you need a Q16 carb? I have a 1250 Dominator that is set up for Q16 that I've been thinking about selling. Running Q16 requires a lot more than just bigger jets. BLP converted my carb for Q16 and they changed the metering blocks, bleeds, jets and upper jets. Of course if you are running EFI then you just type in some new numbers and you're locked and loaded for Q!
[Re: Dave Hall]
#2353392
08/13/17 11:49 PM
08/13/17 11:49 PM
Posts: 4,101 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
That's a good point! I don't know the exact compression as I went from an 88cc chamber to a 72 cc when I put the -1's on it. It was blue printed at 12.9 originally. I was running 116 Sunoco as it was the same price as 114 at the Sonoma pump. I scored a basically free barrell of VP 110. It sure seemed to like the VP fuel better. I went over the block with a scotch brite wheel and it just has this little etch. I think I'll run it for the last couple races after getting the head fixed. With some better ⛽️! Get the shortblock OUT and upside down or at least perpendicular (for cleaning debris) so you can LAP that void out. LAP the whole deck surface, not just locally. See what it takes LOCALLY to get a feel for how deep the void is and if it can be removed. I'd get a feel for WHERE the loading 'ring' of whatever gasket you using is in relation to the void. You can probably take about .003" out pretty easily...just takes patience and time.
[Re: Dave Hall]
#2353551
08/14/17 12:19 PM
08/14/17 12:19 PM
Posts: 19,385 Las Vegas
Al_Alguire
Las Vegas
Dave like we talked yesterday for what you have planned just proceed as necessary. Get the head fixed and throw a decent gasket on it and watch it. Is it optimal, no but will it get you buy the rest of the year, likely so. Obviously the 110 was the biggest issue and the piston tops show some detonation. Watch the oil pressure as well as detonation will KILL rod bearings.
As for the carb, I have one sitting at home ready for Q if you need it. Say the word and it will be on its way. Or send me yours, we can make it ready for Q. Just say the word.
Also the dragster is sitting at the house waiting for you if you need it too. Wish I was closer you could use it this weekend. If you need it to finish out the year or at the ET finals its all yours. Also if you need any bits and pieces I am sure we can help. I have a fresh set of heads as well as the carb..
[Re: Dave Hall]
#2353574
08/14/17 12:48 PM
08/14/17 12:48 PM
Thumperdart
State of confusion
I'm definitely not taking the engine from the car right now. It only has a couple of races to go to finish the season. I'll fix a bunch of stuff this winter. I will clean up the whole surface using a shop vac and my wheel, I have Cometic's on order and cross my fingers using some Sunoco 116 for now. Hopefully I can get the head fixed in time for Sunday. Taking them apart now. I thought the Cometics needed a very fine finish to seal no scratches like above...............
[Re: Thumperdart]
#2353616
08/14/17 01:51 PM
08/14/17 01:51 PM
Posts: 4,457 Washington
madscientist
Washington
I'm definitely not taking the engine from the car right now. It only has a couple of races to go to finish the season. I'll fix a bunch of stuff this winter. I will clean up the whole surface using a shop vac and my wheel, I have Cometic's on order and cross my fingers using some Sunoco 116 for now. Hopefully I can get the head fixed in time for Sunday. Taking them apart now. I thought the Cometics needed a very fine finish to seal no scratches like above............... They can be used with a bit rougher surface than they call for. Since he's trying to finish the year I agree with Al. He will be just fine to finish the year. Pretty damn nice of Al to offer him a carb or to tune up his.
[Re: Dave Hall]
#2353843
08/14/17 07:54 PM
08/14/17 07:54 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
If I need to use a steel gasket with a less than perfect surface I spray on a liberal coat of copper coat, seems to work ok around here even though that is not what the manufacturers call for.
[Re: Dave Hall]
#2353891
08/14/17 09:32 PM
08/14/17 09:32 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
There's no water to worry about at that location. I wouldn't sweat it at all.
[Re: Dave Hall]
#2355016
08/16/17 06:52 PM
08/16/17 06:52 PM
madscientist
Washington
Head is fixed. Now if Summit would just show up... That will seal fine with a cometic. You are close to pooping in the tall cotton.
[Re: madscientist]
#2355033
08/16/17 07:38 PM
08/16/17 07:38 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Dave I wish I still had pictures to show you what happened to me years ago. I had a .030 440 engine that ran 9.80's 30 plus years ago with a stock block and ported 906 heads. I was going rounds but the car kept slowing every round so I kept bumping my dial slower. I lost in the final on Sunday afternoon and loaded up and when I took a leakdown i could tell there was an issue between cylinder 3 and 5 so I pulled the head. Both my block and head were torched over .125 so after a day of making phone calls found a guy 25 miles away that said to bring it over. The head was no problem but with the engine still in the car I lowered the pistons as much as I could and wrapped the cylinders with keyowool and and fiberglass cloth. He checked it out and said he could do it in the car but asked me how I could machine it. As a Millwright we did stuff like this everyday so I told him I would get it close with a 3 inch grinder and then file it to within .002-.003 and it would seal. He said he would charge me 125.00 to weld both the head and block. I then gave him some nickel stick welding rod we used in the mill. He called the next day (Wednesday) and said it was done so I flew up to get my Duster. When I took a look the whole job was finished and filed flat. He told me he couldn't believe that it could be done so he had to try. He did a great job and when I asked how much I owed he said 100.00 (25.00 less than quoted) for more work. He said hey I learned something and by doing that he would be able to apply it in his trade. I put it back together Thursday after work and raced Friday night. That block is still in a street car today and the heads are in my downstairs garage.
