Small Block head gasket? #2351879
08/10/17 02:02 PM
08/10/17 02:02 PM
Wisconsin
wkroncke17 Offline OP
Wisconsin
Looking for best head gasket when going with aluminum heads/iron block?
Will be 10/10.5:1 compression at the most.
How are the Mr. Gasket 3211G?
I have a friend with a spare set, or will buy what is best for that purpose.
Thanks all!!
Re: Small Block head gasket? [Re: wkroncke17] #2351913
08/10/17 03:05 PM
08/10/17 03:05 PM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
I've used the FelPro 1008 gasket (4.180" bore, 0.039" thick, 8.770cc volume) last few times, but this was an iron-to-iron application. Needless to say, very happy with them.
Re: Small Block head gasket? [Re: wkroncke17] #2351925
08/10/17 03:39 PM
08/10/17 03:39 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Felpro 1008 here
wave
Re: Small Block head gasket? [Re: MR_P_BODY] #2351931
08/10/17 03:48 PM
08/10/17 03:48 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I too use the 2008 Fel-Pros a lot. I have slowly been switching some of my more serious builds over to cometics but that's not needed for your build.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Small Block head gasket? [Re: wkroncke17] #2351945
08/10/17 04:12 PM
08/10/17 04:12 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
Fel-Pro 1008 is best ... cost-wise and performance/assurance. MLS gaskets are excellent (and very expensive) but require extremely smooth surface finishes that most machine shops -- on average -- can't or won't perform.
Forget the MrG... you want dependable assurance... get the Fel-Pro 1008 which have a pre-flattened internal wire ring (for high compression sealing) that is wrapped in a Stainless Steel outside armor; also has excellent surface sealing. Torque loss is barely traceable... no need to ever re-torque (unless you want to).
I'm a former Fel-Pro engineer... I know whats' out there.
Re: Small Block head gasket? [Re: wkroncke17] #2351960
08/10/17 04:29 PM
08/10/17 04:29 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I too use the Fel Pro 1008 on my builds.
Re: Small Block head gasket? [Re: wkroncke17] #2351972
08/10/17 04:59 PM
08/10/17 04:59 PM
Locomotion Offline
Locomotion  Offline
Is there any physical difference between the older 1008 that were like a bright blue color compared to the newer ones which are a darker blue? Or is that just a production coating change?
Re: Small Block head gasket? [Re: Locomotion] #2351989
08/10/17 05:34 PM
08/10/17 05:34 PM
MR_P_BODY Offline
MR_P_BODY  Offline
What I have seen over the years is they are the
same.. just a color change and I dont know why
they did it
wave
Re: Small Block head gasket? [Re: wkroncke17] #2352074
08/10/17 08:40 PM
08/10/17 08:40 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I have had great luck with the 1008. My current engine has cometics but we only went with them because they had the thickness we needed.
68 Barracuda Formula S 340
Re: Small Block head gasket? [Re: wkroncke17] #2352134
08/10/17 10:24 PM
08/10/17 10:24 PM
Wisconsin
Wisconsin
Ok so it sounds as if the Fel Pro 1008 is the best choice.
I got the Mr Gaskets reasonable,
It sounds like I should hang them up for back ups and buy Fel Pro??
Re: Small Block head gasket? [Re: wkroncke17] #2352524
08/11/17 06:31 PM
08/11/17 06:31 PM
dogdays Offline
dogdays  Offline
Yep the Mr. Gasket MLS' instructions say surface between 10-30RA, which is pretty smooth. I wonder what a regular Detroit block would measure at? I mean there have been thousands of cars (Neons?) recalled to replace head gaskets and they were replaced with MLS gaskets. I can't imagine Chrysler using a gasket that needed resurfacing of the block and head.
I use the Mr. Gasket 1121G thin head gasket with no complaints.
R.
Re: Small Block head gasket? [Re: wkroncke17] #2354061
08/15/17 02:19 AM
08/15/17 02:19 AM
Kingman, Az
Scojodak Offline
Scojodak  Offline
Kingman, Az
1008's on my 10:1 408 magnum. One nice thing about the 1008's is they compress at .039 of an inch. That's near perfect for quench at zero deck with flat tops.
Dakota for life!
