Re: What small block Mopar electric water pump to use? [Re: dustergirl340] #2350245
08/07/17 06:58 PM
08/07/17 06:58 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Kath.. I've been running the Merziere pump for
about
15 years.. I have 2 of them.. very good product
EDIT
Also.. they make 3 versions of the electric
pump.. a 35,42 and a 55 gal per minute.. the 35
is all you need for racing but for the street
you might want to step up in volume.. I'm thinking
about changing the motor on my smaller one to put
in a 55GPM in my hot rod.. I havent had any issue
with the smaller one but it is a option(and its
just a motor change
wave
Re: What small block Mopar electric water pump to use? [Re: dustergirl340] #2350334
08/07/17 10:26 PM
08/07/17 10:26 PM
Guitar Jones Offline
Meziere I've had mine for over 20 years.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: What small block Mopar electric water pump to use? [Re: dustergirl340] #2350352
08/07/17 10:54 PM
08/07/17 10:54 PM
Chicken coop
dustergirl340 Offline OP
Chicken Little
Chicken Little
Chicken coop
Thanks Mike...and Guitar....and everyone else! Much appreciated!
Re: What small block Mopar electric water pump to use? [Re: dustergirl340] #2350792
08/08/17 04:08 PM
08/08/17 04:08 PM
K
Kiddart Offline
Kiddart  Offline
K
Dustedu please share the water pump set up.
Thank you
Kiddart
Re: What small block Mopar electric water pump to use? [Re: Kiddart] #2350798
08/08/17 04:17 PM
08/08/17 04:17 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Probably one something like this. My small tire car came with one mounted on the frame and I bought two of Andy's water manifolds.
http://www.jegs.com/i/Meziere/680/WP136S/10002/-1
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: What small block Mopar electric water pump to use? [Re: dustergirl340] #2350801
08/08/17 04:19 PM
08/08/17 04:19 PM
TN
1DGEMAN Offline
1DGEMAN  Offline
TN
Meziere is the way to go. One other thought why not get a cooling station like the stock/super stock guys use? It takes 5 minutes to drop engine temp below 100 degrees. If you are doing that much hot lapping what about trans temps?
Real Men shift for themselves
Re: What small block Mopar electric water pump to use? [Re: 1DGEMAN] #2350805
08/08/17 04:24 PM
08/08/17 04:24 PM
PA.
"Little"John
"Little"John
PA.
My Friend makes and sells these.
http://jonestransmissionpumps.com/
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: What small block Mopar electric water pump to use? [Re: dustergirl340] #2350814
08/08/17 04:34 PM
08/08/17 04:34 PM
P
Paul_Fancsali Offline
P
Use a 8 blade pump mech pump Air cool between round using a electric rad fan The electric water pumps are for all out race car with between round charging.
Is this car a drag only car? .
Re: What small block Mopar electric water pump to use? [Re: Paul_Fancsali] #2350828
08/08/17 05:01 PM
08/08/17 05:01 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I've never had any issues with a electric water
pump.. look at production cars.. they run electric..
if they have the flow(most do) there wont be any issue
wave
Re: What small block Mopar electric water pump to use? [Re: Paul_Fancsali] #2350835
08/08/17 05:12 PM
08/08/17 05:12 PM
Chicken coop
Chicken Little
Chicken Little
Chicken coop
Yes it is, for now.
Re: What small block Mopar electric water pump to use? [Re: dustergirl340] #2350938
08/08/17 08:16 PM
08/08/17 08:16 PM
jacksonville,FLORIDA
slammedR/T Offline
slammedR/T  Offline
I bought a CSR pump back in 2007 for my Dakota and ran it as a daily driver till 2009, last year the motor finally died. Contacted CSR and bought a new motor for it, swapped it out and works great when my engine is in the truck, lol.
2000 Dakota R/T, 408 magnum, 727, Indy heads
1000cfm 4150 carb, 93 octane fuel.
motor; 10.258 @ 132.78
200 shot; 9.262 @ 144.69
racemagnum
Re: What small block Mopar electric water pump to use? [Re: dustergirl340] #2350995
08/08/17 10:16 PM
08/08/17 10:16 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Probably more like this, I would like to move to one of these as it would open up fan options for me.
http://www.jegs.com/i/Meziere/680/WP361/...ASABEgJkavD_BwE
68 Barracuda Formula S 340
Re: What small block Mopar electric water pump to use? [Re: Kiddart] #2351067
08/09/17 12:27 AM
08/09/17 12:27 AM
Louisville, MS
Dustedu Offline
Dustedu  Offline
Louisville, MS
Wp-362
Two outlets, I machined cover flat and tapped the engine plate for two 3/4" holes in line win he holes in cover
[/URL]
Re: What small block Mopar electric water pump to use? [Re: WHITEDART] #2735410
01/21/20 08:39 PM
01/21/20 08:39 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Originally Posted by WHITEDART
I would recommend this with a good electric fan. This will help keep it simple.. bolt up and go.. https://m.summitracing.com/parts/mo...fkB0tmuecomsG53O-57UzV1yL4saAtPBEALw_wcB
Dusting off this thread, as I am curious: Has anyone used this pump and figured out a way to hook up heater hoses? I have two threaded ports on the Indy intake; one location can be one heater hose but the other one one will source engine temp.
Just wondering out loud if it's possible.
Thanks!
Re: What small block Mopar electric water pump to use? [Re: cudadoug] #2735536
01/22/20 11:12 AM
01/22/20 11:12 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Thanks!
Just a guess, but if you drill and tap that anywhere on the flat portion near the block water inlets I imagine it would divert some water to the heater core, but I don't know if it would be enough or not.
See my poor illustration with the blue area being the area to open up for a fitting.
Re: What small block Mopar electric water pump to use? [Re: Bad340fish] #2735604
01/22/20 02:05 PM
01/22/20 02:05 PM
cudadoug Offline
cudadoug  Offline
Thanks!
Thanks! I was thinking he same, but was hoping someone was successful before I fire up the drill press.
Re: What small block Mopar electric water pump to use? [Re: cudadoug] #2735656
01/22/20 06:00 PM
01/22/20 06:00 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I guess a concern would be that the heater core ends up the path of least resistance and that side of the engine doesn't get as much flow as the other side. I don't drive mine much in the winter so when I do I just plan on freezing lol.
Re: What small block Mopar electric water pump to use? [Re: Bad340fish] #2735694
01/22/20 09:38 PM
01/22/20 09:38 PM
central Pa.
71Pan Offline
71Pan  Offline
central Pa.
Meziere housing with block off plate that I made Stewart remote pump LOVE IT
Re: What small block Mopar electric water pump to use? [Re: cudadoug] #2735723
01/23/20 01:35 AM
01/23/20 01:35 AM
You need to remember that for water to flow through the heater one side is on the inlet side (bottom hose) of the radiator water pump inlet(suction) and the other side, intake manifold fitting is on the outlet side( hot water to the heater) scope
