Re: What small block Mopar electric water pump to use?
[Re: dustergirl340]
#2350245
08/07/17 06:58 PM
08/07/17 06:58 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Kath.. I've been running the Merziere pump for about 15 years.. I have 2 of them.. very good product EDIT Also.. they make 3 versions of the electric pump.. a 35,42 and a 55 gal per minute.. the 35 is all you need for racing but for the street you might want to step up in volume.. I'm thinking about changing the motor on my smaller one to put in a 55GPM in my hot rod.. I havent had any issue with the smaller one but it is a option(and its just a motor change
[Re: dustergirl340]
#2350334
08/07/17 10:26 PM
08/07/17 10:26 PM
Guitar Jones
Meziere I've had mine for over 20 years.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: dustergirl340]
#2350792
08/08/17 04:08 PM
08/08/17 04:08 PM
Posts: 1,552 Michigan
Kiddart
Dustedu please share the water pump set up.
Thank you Kiddart
[Re: Kiddart]
#2350798
08/08/17 04:17 PM
08/08/17 04:17 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Dustedu please share the water pump set up. Probably one something like this. My small tire car came with one mounted on the frame and I bought two of Andy's water manifolds. http://www.jegs.com/i/Meziere/680/WP136S/10002/-1
[Re: dustergirl340]
#2350801
08/08/17 04:19 PM
08/08/17 04:19 PM
Posts: 608 TN
1DGEMAN
TN
Meziere is the way to go. One other thought why not get a cooling station like the stock/super stock guys use? It takes 5 minutes to drop engine temp below 100 degrees. If you are doing that much hot lapping what about trans temps?
Real Men shift for themselves
[Re: 1DGEMAN]
#2350805
08/08/17 04:24 PM
08/08/17 04:24 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Meziere is the way to go. One other thought why not get a cooling station like the stock/super stock guys use? It takes 5 minutes to drop engine temp below 100 degrees. If you are doing that much hot lapping what about trans temps? My Friend makes and sells these. http://jonestransmissionpumps.com/
[Re: Paul_Fancsali]
#2350828
08/08/17 05:01 PM
08/08/17 05:01 PM
MR_P_BODY
Use a 8 blade pump mech pump Air cool between round using a electric rad fan The electric water pumps are for all out race car with between round charging. Is this car a drag only car? . I've never had any issues with a electric water pump.. look at production cars.. they run electric.. if they have the flow(most do) there wont be any issue
[Re: Paul_Fancsali]
#2350835
08/08/17 05:12 PM
08/08/17 05:12 PM
Posts: 22,873 Chicken coop
dustergirl340
Chicken Little
Chicken Little
Chicken coop
Use a 8 blade pump mech pump Air cool between round using a electric rad fan The electric water pumps are for all out race car with between round charging. Is this car a drag only car? . Yes it is, for now.
[Re: dustergirl340]
#2350938
08/08/17 08:16 PM
08/08/17 08:16 PM
Posts: 733 jacksonville,FLORIDA
slammedR/T
I bought a CSR pump back in 2007 for my Dakota and ran it as a daily driver till 2009, last year the motor finally died. Contacted CSR and bought a new motor for it, swapped it out and works great when my engine is in the truck, lol.
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
[Re: Kiddart]
#2351067
08/09/17 12:27 AM
08/09/17 12:27 AM
Posts: 993 Louisville, MS
Dustedu
Louisville, MS
Wp-362 Two outlets, I machined cover flat and tapped the engine plate for two 3/4" holes in line win he holes in cover [/URL]
[Re: WHITEDART]
#2735410
01/21/20 08:39 PM
01/21/20 08:39 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
Dusting off this thread, as I am curious: Has anyone used this pump and figured out a way to hook up heater hoses? I have two threaded ports on the Indy intake; one location can be one heater hose but the other one one will source engine temp. Just wondering out loud if it's possible. Thanks!
[Re: cudadoug]
#2735536
01/22/20 11:12 AM
01/22/20 11:12 AM
Posts: 8,027 Tulsa OK
Bad340fish
Tulsa OK
Dusting off this thread, as I am curious: Has anyone used this pump and figured out a way to hook up heater hoses? I have two threaded ports on the Indy intake; one location can be one heater hose but the other one one will source engine temp. Just wondering out loud if it's possible. Thanks! Just a guess, but if you drill and tap that anywhere on the flat portion near the block water inlets I imagine it would divert some water to the heater core, but I don't know if it would be enough or not. See my poor illustration with the blue area being the area to open up for a fitting.
68 Barracuda Formula S 340
[Re: Bad340fish]
#2735604
01/22/20 02:05 PM
01/22/20 02:05 PM
cudadoug
Dusting off this thread, as I am curious: Has anyone used this pump and figured out a way to hook up heater hoses? I have two threaded ports on the Indy intake; one location can be one heater hose but the other one one will source engine temp. Just wondering out loud if it's possible. Thanks! Just a guess, but if you drill and tap that anywhere on the flat portion near the block water inlets I imagine it would divert some water to the heater core, but I don't know if it would be enough or not. See my poor illustration with the blue area being the area to open up for a fitting. Thanks! I was thinking he same, but was hoping someone was successful before I fire up the drill press.
[Re: cudadoug]
#2735656
01/22/20 06:00 PM
01/22/20 06:00 PM
Bad340fish
Tulsa OK
I guess a concern would be that the heater core ends up the path of least resistance and that side of the engine doesn't get as much flow as the other side. I don't drive mine much in the winter so when I do I just plan on freezing lol.
[Re: cudadoug]
#2735723
01/23/20 01:35 AM
01/23/20 01:35 AM
Posts: 43,180 Bend,OR USA
Cab_Burge
You need to remember that for water to flow through the heater one side is on the inlet side (bottom hose) of the radiator water pump inlet(suction) and the other side, intake manifold fitting is on the outlet side( hot water to the heater)
