driveshaft # i.d. #2349410
08/06/17 12:38 PM
08/06/17 12:38 PM
Loganville GA.
K
kdsmith07 Offline OP
K
Loganville GA.
the driveshaft # is 3578217 and i've looked but can't find it listed.it's about 54 1/2 center to center of caps and 3.250 dia.with a 727 yoke.any help is appreciated as i don't know where else to look.tia
Re: driveshaft # i.d. [Re: kdsmith07] #2349482
08/06/17 02:17 PM
08/06/17 02:17 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
that part number is most likely out of a 74
Re: driveshaft # i.d. [Re: kdsmith07] #2349488
08/06/17 02:31 PM
08/06/17 02:31 PM
Loganville GA.
K
K
Loganville GA.
could it be a b body with that length?thanks morty
Re: driveshaft # i.d. [Re: kdsmith07] #2349546
08/06/17 04:32 PM
08/06/17 04:32 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
That length and part number did not come up and I do not own a 74 parts book.
You are measuring from the center of the U joint cap to the center of the U joint cap, correct?
Re: driveshaft # i.d. [Re: kdsmith07] #2349565
08/06/17 04:49 PM
08/06/17 04:49 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
3578217 isn't in the '74 Parts Catalog
shruggy
3578317 is - '74 b-body w/225, 318, 400 & 727 (or PP230) - 53.74" lg. & 3.25" dia.
Re: driveshaft # i.d. [Re: kdsmith07] #2349670
08/06/17 07:48 PM
08/06/17 07:48 PM
Loganville GA.
K
K
Loganville GA.
ya,ctr to ctr of the caps is about 54.5 and it's definately 217.thanks for your help guys
Re: driveshaft # i.d. [Re: kdsmith07] #2351534
08/09/17 08:15 PM
08/09/17 08:15 PM
Tucson, AZ
cruzin Offline
cruzin  Offline
Tucson, AZ
Where are you reading this # (3578217) from? If it's on the yoke, that may be the yoke's p/n. The p/n for the driveshaft is stamped into the shaft. Generally it's located 12-18" from the end and not real visible unless you are really looking.
