73 Challenger, need Ignition switch and lock cylinder #2348930
08/05/17 01:19 PM
08/05/17 01:19 PM
St. Louis, Mo
3
318 Stroker Offline OP
St. Louis, Mo
Need to replace the ignition switch and lock cylinder on my 73 Challenger.
Are both parts interchangeable from 70-74 or are there variations for different years. Any good vendors to use?
Re: 73 Challenger, need Ignition switch and lock cylinder [Re: 318 Stroker] #2348942
08/05/17 01:36 PM
08/05/17 01:36 PM
Re: 73 Challenger, need Ignition switch and lock cylinder [Re: 318 Stroker] #2348976
08/05/17 02:36 PM
08/05/17 02:36 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Switch... 70 and laters
Cylinder, 71 and laters... 70 and some earliers 71 got a diff locking setup on collar for the cylinder
Need to note several replacement switches are made now to match several setups, so will need to match your one ( remove one extra black wire they got for example your Chally doesn't use ). Some manufacturer include instructions sheets, but some others not.
Re: 73 Challenger, need Ignition switch and lock cylinder [Re: NachoRT74] #2349318
08/06/17 05:01 AM
08/06/17 05:01 AM
St. Louis, Mo
3
St. Louis, Mo
Thanks Nacho, just wanna make sure I buy the right ones.. thumbs
Re: 73 Challenger, need Ignition switch and lock cylinder [Re: 318 Stroker] #2349454
08/06/17 01:41 PM
08/06/17 01:41 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Here is ( for example ) one ign switch with instructions sheet, made for several diff 70s setups.
https://www.oldsobsolete.com/products-pa...rg-warner-cs82/
Good priced if you ask me BTW!
If you get it, get the instruction sheet scanned of pictured for tech references around! ( send to me LOL )
Several replacement switches got a diff rivets disposition on backelite, maybe due the extra functions like the think black wire mentioned ( which I have no idea of year and apllication ), but fits and works the same on steering column collar
( EDITING: nevermind, says out of stock )
Re: 73 Challenger, need Ignition switch and lock cylinder [Re: 318 Stroker] #2349472
08/06/17 02:08 PM
08/06/17 02:08 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
This will be the lock you'll find on the cylinder... round press button
Re: 73 Challenger, need Ignition switch and lock cylinder [Re: 318 Stroker] #2349476
08/06/17 02:12 PM
08/06/17 02:12 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
70s and I think some earliers 71 are a flat tab...
And release location is kinda diff on collar, like the steering collar must be to fit in it
